Note that Amir means the more expensive micro version. The nano has much less power.
Thanks Veri ... its amazing how the micro iDSD Black Label, a usb/battery powered amp , can deliver such power and also measure well ...
Fwiw, I use an O2 amp with my HD6XXs, it can drive them to painful levels with the volume knob at slightly past 11am and low-gain setting without noticeable distortion.
Danke für diese Antwort in Deutsch! Know you, I can no good English understand!Leider nicht, Sie irren sich.
Es ist nur die weise worauf es sichtbar gemacht ist durch das Programm.
Das sind keine 'Transients'.
Im diesen fall sollte die frequenz davon etwas im MHz bereich sein.
Deutsch ist aber nicht mein eigenes Sprache.
This is really funny. Who do you think you are? The forum sheriff? The forum teacher?Good. If you are not prepared to take on board the technical knowledge that is held by members here then you are wasting peoples time. The explanations as to why you are incorrect are very simple and frankly obvious. If you choose dogma instead of learning that's up to you.
I think you are going to be one for the ignore button.This is really funny. Who do you think you are? The forum sheriff? The forum teacher?
You do not decide about if and when someone "qualifies" for this forum.
And dogma? LOL, I work with RX's spectrogram since 2007 and know how to visibly distinguish the attack time of a sound from its sustain time.
You know what dogma really is? Claiming that digital impulses and steps are "invalid" and useless.
See also my answer to the other expert.
Your turn!
The main reason would be the better support of JDS Labs over Schiit.Would there be a reason to get the El DAC vs the Modi 3?
D30 is a better price/performance. Similar enough USB performance. EL DAC is a better over S/PDIF, and doesn't have the ESS IMD Hump(because AKM chip). Aesthetically, I like the EL DAC a lot better than the D30. Both are good DACs.Anybody?
Doesn't D30 use cirrus logic? No IMD humpD30 is a better price/performance. Similar enough USB performance. EL DAC is a better over S/PDIF, and doesn't have the ESS IMD Hump(because AKM chip). Aesthetically, I like the EL DAC a lot better than the D30. Both are good DACs.
Hmm, you're right. I confused myself with many of their other products like D50, D10, DX7(Didn't have the hump), DX7S featuring ESS chips. D30 does use Cirrus Logic chip.Doesn't D30 use cirrus logic? No IMD hump
They're near the same, on the condition you're using SPDIF with EL Dac.How would this compare to sdac? I know EL Dac is quite a bit more expensive though. I guess at that price, Topping D50 beats EL dac?
