Review and Measurements of IOM NCore Pro PWR Amp
maty
Tarragona (Spain)
From the Hypex NC252MP PDF
and CMR only 71 dB.
PSRR?
The PDF is well specified. Sellers/assemblers, not all, who cheat by not specifying that they are peak watts and not continuous.
BTW: "Apply sufficient cooling" -> bad idea a closed box without enough holes (and at the least harmful site, far from audio electronics) and/or heatsinks.
maty
Tarragona (Spain)
In order to compare with the state of the art (known public) in class D amp:
PURIFI 1ET400A, from the PDF
In my second audio system I have a little coaxial KEF Q100 with true 85 dB/W/m and 3.9 Ohms minimum. If I want 95 dBSPL peak wich each speaker at 3 meters: I need 50 watts peak at 8 Ohms -> 100 watts peak at 4 Ohms (remember: 3.9 Ohms minimum and impedance graph is like 5-6 Ohms nominal and not 8 Ohms as KEF says).
My requirements: 80 dBSPL continuous with my very good recordings of DR15 -> 95 dBSPL peak.
https://www.doctorproaudio.com/content.php?2273-calculators-proaudio-sound-dmx&langid=1#calc_spl
https://www.audiosciencereview.com/...mplifiers-to-test-and-review.2238/post-187193
PURIFI: short term 450 watts at 4 Ohms. Then, 1/5 -> 90 watts continuous at 4 Ohms (without protection being activate, it is an estimate). It is a very good value to my speakers and without problems if I switch to a larger room and more demanding speaker! The calculations are overestimating the required power, so I will not fall short.
If we add forced cooling with a silent fan(s), it can supply more continuous power.
PS: with modern commercial music, usually DR < or << 10 dB you need much less power peak!
boXem
Europe
Its not a lab. Thats the office. It just happened to be convenient to do the video there for various reasons.
In any case we arent making satellites, clean room conditions not required and no, static is not a problem. ;)
Your office is nicer than mine ;).
Agree on clean room, less on static. It's really climate and people dependent (my son can't touch anything metallic during winter without getting a discharge).
maty
Tarragona (Spain)
Sal1950
The Chicago Crusher
Central Fl
Makes the place look classy ;)
March Audio
Albany Western Australia
and CMR only 71 dB.
PSRR?
@maty Already demonstrated you are wrong. Watch the video. It sat there before the test warming up at 1/3 power (80 watts) for over an hour before the FTC 5 mins at 250 watts.
Also note the data sheet states RMS power not peak.
What is there you dont understand about this? You are just filling up yet another thread with garbage.
It is, as the Purifi documentation states, the long term power output will be limited by thermal characteristics of the implementation.
Remember its the same guy who designed both modules.
March Audio
I wrote TRY with RF/EMI fitlers. Sometimes it seems that I should use more rich edition.
I like to check things for myself, hence I bought a cheap second-hand AVR to experiment with it and then apply it to a new one. The problem is that now it sounds great and I have FM Radio to listen to classical music and learn (they have a low quality MP3, despite being public). As long as I do not verify it for myself, I will keep writing try. If I build the only class-D amp that really interest me, PURIFI 1ET400A, I will do the test. If there is or does not improve, I would tell in ASR, even if there were those few..
If it does noy need it, much better, we save our money!
That wont stop 50/60Hz mains noise, in fact it may make it worse due to the Y capacitor - which is precisely why Bruno objects to them.
You have been told previously the EMI issue is already in the case and why thicker cases arent any solution, so why did you repeat this stuff again?
March Audio
In
@maty I think the 1/5th power quoted in the Hypex data sheet is only a reference to the average power contained in a typical music signal, its not referring to the power capability of the amp as it doesnt make any sense and is not borne out by actual testing. The long term power output will be limited by thermal characteristics of the implementation.
March Audio
Nice to see another hypex solution.
I still find the plate amps a better value if you can DIY your own case. A fa251 is way less than what the OEM's want for a fancy box.
Possibly. Im pretty sure you cant bypass the A to D and dsp with an analogue input, however you could always completely rip the amp module out.
Its a misleading comparison in terms of value however. How do you value your time to build it? How do you value a manufacturers warranty (mine is 3 years). I do encourage people to diy though, it can be very rewarding.
VintageFlanker
Paris
@March Audio, I'm sorry, but IMHO, that is not @maty who is wrong, but datasheet from Hypex. ;) I still don't understand this "50W continuous power". Also, thanks for clarify power specs weren't peak either.
Ron Texas
It's not a job for Sherlock. 20% of peak power. BTW, Nord still advertises (as of yesterday) 200W @ 8 ohms for the NC252MP and Hypex still has the datasheet for download. Perhaps the board was revised and Nord still has the old ones.
Loud music in home sized rooms is not played at over 10W continuous. The FTC standard created more problems than it solved and probably caused consumers to spend money on thermal solutions which made no difference in even hard actual use.
Ron Texas
BTW, the data sheet for this module gives 1.66v as needed to drive the amp to 250w @ 4 ohms RMS, but 2.34v peak. If I have a DAC with a 2v rated output, is that RMS or peak and can the typical DAC reach a peak output higher than the typical 2V rating? In other words, what do you really need to drive this module, especially if you don't have a balanced DAC?
March Audio
Yes, but thats not the issue here, its his ignoring of information and explanations that are posted and propensity to spam every thread with masses of irrelevant information.
VintageFlanker
Paris
Perhaps. The datasheet has been updated quite recently (July 2019). Still, neither @amirm unit or @March Audio one is able to reach 200W/8ohms.
The max input being given at 6.61dBu (1.66V) for 250W/4ohms, you may theoricaly reach that amount of power with a 2V DAC. Unbalanced is not recommended by Hypex, however (though I actually use RCA with two monoblocs - NC250MP with no "audible" issue). I would say the ADI-2 DAC is the perfect match for this kind of amp. What is your DAC?
