Review and Measurements of Hypex NC400 DIY Amp
DonH56
Monument, CO
lucadoc
France
Nope, by looking at the plate I could say that it's limited at 120hz...but I'm not sure
5)Low Level Filter Bypass - In = Filter in operation - Out = Filter Bypassed.
L.F.E. Position the filter is opened wide to allow the optimum performance from processor
6)Frequency Contour, set up so as to integrate with main loudspeakers.
restorer-john
That answer is not entirely correct. It only applies to class D amps with floating/balanced outputs.
Here's the OEM NC-400 output section for reference.
Julf
Amsterdam, The Netherlands
boXem
Europe
Thanks! Clearly shows the output being ground-referenced, so not floating nor balanced.
To make things clear for everybody, this doesn't mean that it can be tied to something that is not floating: feedback is taken at both FBLH and FBLC. Tying FBLC to a fixed point would create a mess in the feedback structure.
Julf
Not sure about that, as FLBC is already tied through only 0.3 Ω (the 3 parallel 1 Ω resistors) to a fixed point - ground.
Julf
I have to admit I didn't dig in further.
But...
Fair enough, problem is that without further explanation, the Hypex text could also mean "don't assume it is OK to connect the speaker return to whatever ground point".
Julf
meinhard57
I thought the group might like to see the finished product - Hypex NC400 Full Dual Mono DIY Build, using the Ghent 300mm case. BTW - I am not bragging, just for info :). I didn't like the binding posts that Ghent supplied, so I sourced some pure copper ones from AliExpress (took 3 weeks to arrive). Also, Ghent supplied screws that were too short for the LED board - had to go out and but some at the hardware store. Overall - no complaints - the Ghent case is really beautiful! There is another version of this same case that can be used to build a 3-channel unit (although it is a little tight). Total unit weighs in at 11.75 lbs.
boXem
Europe
Nice!
A small improvement you could try to implement is to have the speaker cables connected to the boards in a way that avoids forming a loop. This would decrease the EMI inside the box. But I am nitpicking.
Julf
Nice!
Not just nitpicking - Bruno has made it pretty clear that that is how it should be wired. The cables should definitely not go out in opposite directions.
meinhard57
Nice!
Thanks for the comment - how would I do this? Is the issue the way the speaker cables are connected on opposite sides of the terminals? Or the length of the cables? I appreciate the input... Bob
Julf
The connection on opposite sides. Ideally the cables should go out towards each other. You want to minimize the loop area (especially near the circuitry).
meinhard57
Thanks. Hard to do with 12 AWG wire, but I’ll give it a shot. Bob
boXem
Europe
Do you have a link where he explains why?
From my measurements on other Ncore, it was quite heavily impacting channel separation, I would be curious to learn if Bruno identified other effects.
boXem
Europe
Well, 12 AWG on such a short length is just for bragging rights (very important when DIYing I must recognize).
If you have smaller gauge in a drawer, that will make your life easier.
