Is there a higher wattage PSU that can be used with the NC400 modules?
Any power supply with the right voltages can be used. If you want to have it easy and use the Hypex ones, the SMPS1200 is the most powerful. It is overkill for one nc400.
By the way, can we use the proper term "power" instead of the colloquial, amateur-ish "wattage"?
I thought there was maybe an issue using the 1200 and it's rail voltage being too low or is that a solved problem?
As has been noted a few times, even in this topic (I learned about it here), the issue with using the SMPS1200A400 for the NC400 is that it's Vdr ouput is just slightly lower than the requirement for the NC400 (by 0.4V!), so the NC400 creates its own from the main supply line, causing higher heat dissipation in the NC400 than if an acceptable source was provided. But, the pair work just fine together, as seen in example builds (that are in use). Technically, the SMPS600N400 is a better match (though with worse heat sinking), for a single NC400.I thought there was maybe an issue using the 1200 and it's rail voltage being too low or is that a solved problem?
Indeed. I find Hypex to be one of the most transparent ones in that respect. See below
Well I think it's been explained pretty clearly now. You don't have to look up the data sheet because the amps do what they say on the tin.That is indeed one of their better data sheets, even though it's not even for an amp module. Notice how it differs from the UcD sheet I referenced. However, my focus is on the exaggerated listing of products using their boards. So, retailers or system integrators, essentially.
Just as I wouldn't expect to have to look up a Sanken spec sheet for a typical class AB amp, I don't expect to have to research Hypex module sheets for designs using their boards. I expect the retailer/system integrator to list the amplifier power of their implementation accordingly, as continuous and max.
Perhaps I've taken this thread far enough off track...
I bought two sets of NC400 mono kit (complete kit), which will be received tomorrow.
It is expected to be paired with B&W 606 speakers.
How did the build turn out? How do they sound?
This is a review and detailed measurements of a DIY power amplifier based on Hypex NC400 amplifier modules.
As it is, I can wholeheartedly recommend hypex NC 400 modules for power amplification. Yes, the pink panther is happy!
This seems to be a very easy DIY project although I caution you to NOT engage in it if you are not comfortable and knowledgeable about mains wiring and voltages. You can easily get yourself shocked or killed. So buy an already made one if you are not able to build one safely.
Ncore's distortion is so low that internal wiring layout can make a big difference. Those 4ch Dentecs make me cringe, but many DIY assemblies do also. In particular, they have their amplifier wiring too close to the output inductors. I wouldn't be surprised if there were measurable differences between channels.
I can't find it now, but before I built my Ncore and UCD amps, I read everything available at DIY audio and found a post where Bruno got mad at people shooting themselves in the foot, so he explained how to layout the wiring so as to not create problems.
In particular, from what (little) I can see of the wiring of the 4-channel build, they should (and could) have tightly twisted the output wire pairs together to minimize "loop area" there. That is probably easily corrected, if desired.Ncore's distortion is so low that internal wiring layout can make a big difference. Those 4ch Dentecs make me cringe, but many DIY assemblies do also. In particular, they have their amplifier wiring too close to the output inductors. ...
Yea I've seen the manufacturer claims. But as always, testing can sometimes reveal different results. I was more curious if the rated power claims of the NC400 were ever confirmed in a follow-up review or someone else testing it (as the original review by amir fell short of the claims and all that could be speculated was the PSU limited it).By its specs, a single SMPS600N400 is able to drive a single NC400 to its full rated peak output power into 2 ohms (580W), 4 ohms (400W) and 8 ohms (200W). It was designed specifically for exactly that:
Hypex datasheets were also done with AudioPrecision and are usually close to what Amir measures, so I think you can trust the datasheet info.Yea I've seen the manufacturer claims. But as always, testing can sometimes reveal different results. I was more curious if the rated power claims of the NC400 were ever confirmed in a follow-up review or someone else testing it (as the original review by amir fell short of the claims and all that could be speculated was the PSU limited it).
