I have built and used the two variants of NC400 stereo amps that Ghent supports, the Ncore-SE(200W) and the Ncore-SE(300W), where the difference is only the width. Both go together fine. The 300 mm wide case costs a bit more, but is less cramped inside, and obviously, has better cooling. In both cases (pun intended), I used a single SMPS1200, as I prefer it for heat sinking and total dissipation*. I used a bit of thermal compound under all three modules to get a bit lower device temperatures. I don't feel like I'm missing something relative to two mono cases with SMPS600s (done that too!).The start of this thread, or maybe other threads I've read, raised some doubt about the quality or long term viability of the SMPS600. Other posts I've come across suggest that either, or both, the SMPS600 or 1200 may have been upgraded recently. So is one "better" than the other in terms of long term viability? Also, is there a post or thread on just how to bridge the NC400's?
Then again, maybe I should just take audioBliss's advice and stop sweating it and just build the mono's from hypex (although I prefer the stereo kits from Ghent as it would work better with my system and would only require one power cord).
* Others have noted that there is a shortcoming of the SMPS1200 for driving the NC400. The NC400 has its own Vdr regulator in case there is inadequate voltage from the power supply. The Vdr value from the SMPS1200 is about 1V short of meeting that requirement, so the NC400 provides it, and then each one dissipates about 5W more (about doubling its idle dissipation). Presumably, the SMPS1200 then dissipates a little less than it would, otherwise.
FWIW, I was deep into the case and assembly specs for a 3-channel build with a single SMPS1200 (more than adequate for a center speaker plus two surrounds, with the matching two channel case for FL and FR), but I've stopped that while I sort out my goals with Purifi module amps.
