Veri
- Joined
- Feb 6, 2018
- Messages
- 9,664
- Likes
- 12,314
High-end western DAC companies may have implicitly or explicitly relied on such license not be available to low cost chinese companies.
That is probably true, yes.
Hi everybody . . .
X26's I2S port sounds very good.
Pi3+ >> FifoPi >> I2S >> X26
After completing the experiment, I connected it with the UF.L cable .I have no doubt that 6-8 inches of unshielded, untwisted jumper cables carrying high frequency, high speed IIS signals will sound "very good". Looks like the wires are all bunched together with a cable tie. Obviously there will be no crosstalk, ever.
Nice.
Hey there, none that I can hear. I took my headphones off and switched between different sample rates.For those members that own this DAC, are there audible relay clicks from this device when switching source sample rates?
Android (Galaxy Note 9 via USB) works well using USB Audio Player Pro and in other phone apps in general. However, I run into an odd issue.
Whenever I play 192khz files, and I skip around within the song, or skip to the next track the songs severely glitch. The song slows down to about .25% percent speed, and then sounds like distorted 8-bit 1980's video-game music. Skipping around the track or even the album would give the same glitch. The only way to clear this is to exit the album. I can play any other high resolution PCM and I can't replicate this.
There are much more expensive DACs using off-the-shelf DAC chips.Should be cheaper given the fact it utilized an off the shelf DAC chip.
And none of them sound as good as DCS or Chord. You can get a DCS Debussy for $5000 which sounds expensive but when you factor in having to upgrade 3 to 5 times over the period you own the Debussy you come out with a lot better value as you avoid listening to inferior audio quality and still have an outstanding resale value when you upgrade to the latest DCS product like the Bartok.
Can we have a reference substantiatung this statement please?
I think this is meant to be the THD:An honestly stated THD number is suspiciously missing. Not a good start.
