Review and Measurements of Gustard DAC-X26
The amplifier runs really warm, not hot, but close to it. Butter melting warm I'd describe it. I'm not sure if this is normal or not.
Mine does the same thing.
Toslink does not work with 192khz files from my computer or my iBasso dx200. No matter what settings I put within the DAC, it will not play 192khz.
The unofficial limit for Toslink is 96 kHz. Some devices do better. Others do not. GPLL settings may impact this. Have you tried it?
deafenears
Same here, I was surprised at how warm it runs.
Anyone else having issues with the volume up button (on the device itself and not the remote)? Where instead of increasing volume, it changes the input type (same function as both left and right).
Topher5
For mine the up and down buttons on the device work the volume just fine. I haven't had your same experience where it switches inputs, I'll play with it later to double check.
Topher5
Hey there, I did play with all settings including GPLL etc. The only thing that would happen when I turn to bypass, would be the screen would rapidly flip back and forth from 192khz on and off with no sound.
It's too bad optical doesn't work with 192khz, it works just fine on my SMSL SU-8 Version 2. ( It also doesn't work on my Sony TA-ZH1ES, but then the Sony manual lists maximum 96khz, and the X26 manual lists optical max to be 192khz. Even with the Sony 192khz over optical would play, but then skip every ten to fifteen seconds, rendering unusable to me)
linh0983
Toslink does not work with 192khz files from my computer or my iBasso dx200. No matter what settings I put within the DAC, it will not play 192khz. (Meanwhile my SMSL SU-8 Version 2 plays 192khz via optical just fine.) I do not want to only depend on USB so I wonder if this DAC can even play 192khz via Toslink. I also cant seem to get DSD over PCM to work via optical either.
My x26 . Toslink work with 192khz files . . .
linh0983
Lol with video proof no less! I even tried different cables. I'll give it another go. When did you get yours?
My stranport . . . ( Digital out put : AES , BNC , Optical & Analog out : RCA ) .
Topher5
Hey does DSD over PCM work with optical for you as well? If so, I'd definitely try to get an exchange VS a refund
Old_School
One issue that has not been raised about the Gustard X26, is why after going all out to achieve a virtually perfect technical performance, did they not proceed one step further and get MQA licensing?
JohnYang1997
China
well mqa is bullshit why not just get dxd
Patrick1958
Belgium
Certain brands offer identical dacs with and without MQA. For instance Matrix Audio :
- Matrix Audio X Sabre Pro without MQA : 1.595 €
- Matrix Audio X Sabre Pro with MQA : 1.845 €
That's 250 € difference you pay for listening to a partially lossy codec.
That would IMO put the Gustard X26 in a price range not many people are willing to pay.
Problem could be on MQA side (being concerned about licensing to Chinese companies). Do we have examples of other smaller brand Chinese companies with MQA in them?
Veri
Besides Matrix I don't think so. ESS is bridging the gap with their upcoming new MQA-capable chips though.
That would solve the implementation barrier. But licensing needs to be there and having done that in the past in my corporate work, it can be tricky.
There is also some stigma attached to such licensing. High-end western DAC companies may have implicitly or explicitly relied on such license not be available to low cost chinese companies.
