Review and Measurements of Fiio K5 Pro
RSV
Yep the driver was the problem. I reinstalled it and now it works perfectly. Thanks for the help!
raif71
Since we have several users here, so how are you guys at volume/gain level? I'm currently happy using gain 1 and volume around 11 for pop music and above that when listening to classical. So far never above 2 oclock. Appreciate some feedback ....owh, I'm using Senns 660s.
TonyM
Hi guys,
anyone using this with Beyers DT1770s? Thinking of replacing my E17 Alpen that is used in offive exclusivly so no need for a successor to be transportable.....
Cheers
CRKebschull
Germany
I now got the ATH-MSR7 to go along with the Sennheiser HD58X Jubilee. Both in use on low gain, the HD58X obviously get dialed up higher on the volume (12 o'clock - 3 o'clock) than the MSR7 (which is quite loud at 12 o'clock) (my ears of course, YMMV).
Rockfella
Gurgaon, India.
Rockfella
Gurgaon, India.
How about the K5 pro VS SMSL M 300? :)
Rockfella
Gurgaon, India.
Kosta
New Zealand
With 58x I haven't got past 12 on low gain
dreadknot
taylors ,sc
thoughts on cost vs performance which is better to use the FiiO K5 Pro as just an amp at 1.5watts at 32omhs at 150$ vs schiit ASGARD (as just an amp no module
addon )3.5watts at 32ohms for 250$ which is better an has less distortion , im planning to drive my set of m565 with possible future upgrades so more juice tha
better. my max bugdet for an amp is that includes shipping is 350$ ,maxxevv suggested the SP200 but if might be overkill but useful for future can upgrade
how would it compare to the FiiO K5 Pro and, schiit ASGARD. of the three opitions which would be the best to pair with my SMSL SU-8 version 2 dac id really like to
take advantage of the xlr outputs ?
my pics are of my old setup
Dipypang
Guys, is K5 pro A DAC/AMP or just a DAC which i need to purchase an AMP separately?
And will this fit my old sennheiser momeuntum v.1 headphone with 18ohms impedance?
Veri
It's a DAC+amp all in one. And yes it's suitable to your momentums.
Mr:River
Anyone with the dual K5 pro + HE400i?
I bought the HE400i but it hasn't arrived yet, I have no idea if the K5 will power the HE400i well.
raif71
HE400i has about 40 ohm impedance so it should be ok with the K5 Pro.
flipflop
