Review and Measurements of E1DA 9038S BAL Portable DAC & Amp
I just tested the first 10 samples from the new production 9038SG3. No or light-load(300ohm should be similar) 3rd harmonic within -140..-128db range, average about -133db. THD+N reading 0.00015%. Quite consistent results
thanks to Susumu.
Does 9038SG3 susumu has lower THD+N compare to 9038D even it has susumu already? Also why is that?
No, 9038D has better sinad/TDH+N but only due to lower N(noise). Some 9038D units have THD+N 0.00012%(because of dynamic range over 125.5db(A)), as I mentioned, ES9038Q2M has undocumented tolerance, and some samples are WOW, some so-so and I throw them out.
How did you tell which is WOW and which is so so? Do you have to measure them one by one? That is a lot of work to do.
I did measure all, you can see my video about the same for 9038S, it takes a few sec per unit.
Wow, that is so nice! Thanks so much for doing this, I will be buying one for sure!
We should collect some time for amirm :-)
24 hours are not enough for a mens live per day ;-)
i am really interested to see the differences between D and S
Which firmware-version will/should amirm use for testing?
9038D_MCLK_12MHz_LinPhase_Slow_A_noSTBY.hex or a different one?
@IVX I find the default microsoft driver better with volume than the comtrue one for Windows 10 in terms of power deliver and granularity of control.
