Hello everybody!
I am a very happy user of the tremendously musical E1DA # 9038S G2 with a TempoTec V1, a wonderful set, but too bad the cable supplied with the # 9038S, so stiff, so big!
Can you give me advice for buying on Aliexpress or better a diagram for DIY cable USB C to USB C?
If it behaves like my little old Hiby player, there is a setting to use an external dac.Hello, I'm a little surprised by your question, in fact normally it's plug and play!
What is your problem?
Oh thank you, seen that.There was a comparison vs a few other dongle posted a couple of pages back
With WAV + TempoTec V1 + E1DA #9038S, I think it's less than 8 hours.
But I will control more seriously
For me, never FLAC
May I suggest to check FLACs rather that WAVs (...)
... FLACswhy not ?
... FLACs
If I understand that you suspect that reading a WAV requires more energy than reading a FLAC, you have given the answer , I believe
For me, never FLAC
It could be interesting to take a serious test!
If I had time...
If capacity is 1200Ah you don't want to abuse it and will hopefully start recharging the battery at 25-40% level if you want the battery to work around 2 yrs.Oh thank you, seen that.
So essentially it drains +-500mW while playing 44.1 / 96 FLACs. I assume at 5V? So that will be 100mA current?
Taking as a reference a Tempotec V1 as a USB source (1200Ah battery in there) the E1DA alone would suck the battery dry in 12hours, which equates in a guess of 8h playtime for the pair. Am I on the right track here?
