When streaming to CCA, I need to set Qobuz to CD quality; otherwise I get frequent stutters.So in your instance you have to manually change the streaming quality when using your CCA?
BTW, if I set Qobuz max quality to 24/192 and also play a 24/192 album, during actual playing on CCA, Qobuz and my DAC display 24/96 resolution. Either the CCA requests 24/96 resolution from the server or it is chosen by the Qobuz server (it knows when it is connected to a CCA endpoint).
In truth, however, I only use my CCA for internet radio and podcasts. The CCA's lack of gapless support is a serious problem with some classical music albums (my primary listening). The record labels sometimes break up long continuous music into multiple tracks that will play fine when gapless is supported, but without gapless there is a brief pause at each track boundary.
