I have Qobuz and Apple Music and neither stutter. How fast is your internet connection?
100 MBit/s, so that should not be the problem. 4K video streams fine, too. I think it is specifically the CCA that is doing this.I have Qobuz and Apple Music and neither stutter. How fast is your internet connection?
You need a 'mini toslink optical cable'.I got a Chromecast Audio puck in a swap of various things. I was thinking of plugging it in and use it as a streaming device.
I have a few questions, I would be grateful if I could get answers to them. Sorry if this has already been addressed in the thread, but how do you best plug it into a DAC that has these inputs:
I'm using a Lenovo Tablet with Android 10 and Spotify. What apps are needed/can you recommend to make it work?
I don't know if I have the right type of cable between the Chromecast Audio and my external DAC, but I can fix that.
I read somewhere that it seems to be tricky with software upgrades to Chromecast Audio, is that true?
If it turns out to be more convenient with a Wiim mini as a streaming device together with my tablet and Spotify, I can sell this Chromecast Audio. But since I have it, I still want to see if it would work.![]()
Use the optical output of the CCA into the optical input of the DAC. The CCA connection is one of these dual use ones, where you can either connect in analogue or optical fashion. Normally, you connect the CCA to your wifi (read the manual). It is widely suported by streaming services (probably more than by any other streamer). As for updates, there recently was an issue with an update, but this was recognized and fixed. I think it is a great little device, and I use it in an otherwise pretty high end system
Ok, thanks for the answer. So it powers up via mini usb jack and then 3.5 mm cable to Toslink into the DAC. So far, a walk in the park. I can buy such a cable today or tomorrow and plug it in.You need a 'mini toslink optical cable'. View attachment 451943
I don't think there is any need for third party apps. You will set up the device using Google Home on your tablet. You will then find the device using the Chromecast button in most apps, including Spotify.Ok, thanks for the answer. So it powers up via mini usb jack and then 3.5 mm cable to Toslink into the DAC. So far, a walk in the park. I can buy such a cable today or tomorrow and plug it in.But this gets a little trickier. That setup didn't give a good test results according to Amir but it got much better, as good as it can even be, when plugged in: Fortunately as I mentioned, I had Roon to test so I powered that up,...
I don't use Roon but apparently according to # 74 you get really good results with this app:
Okay, but how does that app work with Spotify? If it works with Spotify?
I can confirm that chromecasting from the Spotify app on iphone or android phone to chromecast audio works, as do Tidal, Qobuz, Deezer, Amazon music. Haven't tried the Windows app for Spotify, but all others, and they do work.Which also doesn't work with Spotify. It was probably the fastest download and then uninstall I've ever done.
View attachment 451951View attachment 451952
Spotify and Tidal, both Windows' apps work with Chromecast tooI can confirm that chromecasting from the Spotify app on iphone or android phone to chromecast audio works, as do Tidal, Qobuz, Deezer, Amazon music. Haven't tried the Windows app for Spotify, but all others, and they do work.
Concur. In that case, everything gets resampled by Windows to 16 bit / 48 kHz and without particular care to do it right.Avoid playing from the browser, however.
VLC supports Chromecast Audio, but I have to reset my laptop's wireless connection every time (I've never worked out why and suspect it's the laptop itself...Unfortunately regarding Spotify and CCA, I saw this in the thread:
Spotify premium quality is normally 320 kbps Vorbis, but Spotify streams to Chromecast using 256 kbps AAC:
https://community.spotify.com/t5/Other-Partners-Web-Player-etc/Chromecast-Bitrate/m-p/3162774#M36847
https://community.spotify.com/t5/Li...-possible-Quality-to-Chromecast/idi-p/4523194
My speculation is that Spotify got lazy and implemented Chromecast streaming the same way for all users, so they don't have to distinguish between premium and non-premium subscriptions.
That was #107, written almost seven years ago. Maybe it's changed now? Any upgrade that enables 320 kbps Spotify via CCA? Anyway, I didn't find any information about that.
Edit:
The Wiim mini seems to handle Spotify 320 kbps Vorbis though.I might sell the CCA and buy a Wiim model instead.
I'm going to follow a bidding on a CCA now. Let's see what the seller gets. Starting bid $40:
That's the question, when will it be audible? Favorite question here at ASR.VLC supports Chromecast Audio, but I have to reset my laptop's wireless connection every time (I've never worked out why and suspect it's the laptop itself...
I've got a great sounding 128kb/s music file that I reconstituted up to WAV. I doubt anyone would ever know.
Spotify for me (plain free version), also sounds great with the music I've streamed from it. It's more than good enough to hear production differences...
There has been a bunch, some of them quite scientific. The usual conclusion is that the difference is only audible in a few rare (pathological) cases (keys jingling etc.), and even then only if you really know what to listen for. I guess we still have JJ Johnston (the "father of AAC) here on this forum.Aren't there blind tests you can do to see if that's the case?
