Would a Cambridge audio cxn into an external dac sound better than a chromecast audio into the same dac ?
You will need an optical to coax adapter.
It is bitperfect, unless you configure your PMS to transcode. It does not do transcoding for audio streams on local network by default.Is anyone able to confirm:
Is casting using the Plex app on an android device to CCA bit perfect or compressed?
Get an optical switcher? Something like https://www.amazon.com/Digital-Toslink-Splitter-Cable-Black-Video-Game/dp/B06ZZ2BC9X/Hi everyone,
I am running a smsl SA300 amp and sanskrit 10th mk2 DAC.
I was thinking of getting a CCA and connecting it to my DAC for streaming.
The problem is the digital input of my DAC is already occupied by my TV.
Is there a way of connecting CCA to the DAC using USB or coaxial?
Show off was never the idea. I've spend ~1000 US$ for the setup so far, so I really wanted to know if spending 150US$ makes sense. Thank you for the reply.Not really. The $150 would be to be able to show off and feel comfortable that you are above average.
I am very satisfied with my CCA used as a streamer between Roon and Hugo 2, it blows the USB connection from my desktop away.
In what way does it "blow away" the USB connection on your desktop? What OS are you running? What music playing application?
