On your TosLink-vs-Coax experiment, I'm eager to hear how it turns out
Listening now, TL;DR...given up trying to find a tangible difference
I’m using a Van Damme optical cable and a Van Damme coax - so not escoteric, but good value and not cheap shit either (expensive digital is snake oil IMHO), anyway there is a parity on price/performance between each so at least evens the playing field for the test.
However yeah really nothing at all between them. I had my daughter switch for me whilst in my listening position, and then later I was changing it which meant I was near field to the speaker, in either case nothing between them.
I’m not sure there’s much of a difference with the Node 2i and Modius either. Slightly smoother, slightly less busy background, but really there’s such narrow margins it’s almost irrelevant.
For what it’s worth to give an idea on the kit I’m using:
Node 2i -> Van Damme optical cable -> Schiit Modius -> QED Reference 40 RCA cables -> Audiolab 8300A -> QED Silver XT cables -> KEF R5.
Pretty decent in my opinion. And the sound is simply stunning that I’m listening to, but in terms of discerning a difference then yeah sweet FA really! YMMV and headphone listening I’m sure would reveal more.
I’m going to keep the Modius, it looks great in my setup and yes there is a slight improvement and that smoothness just helps take an element of sharpness that can sometimes be heard. So I do recommend it, just don’t expect a gulf of difference (which I was, naively!).
I’m curious to try an expensive DAC like a Chord Qutest which I intend to demo at some point, but I think I’m pretty much at my end game setup right now anyway. Perhaps I’ll try XLR from the Modius to my amp next....but I’m slightly reluctant given the price of equiv RCA leads to make it fair (QED Ref XLR’s ££!)
