It should be the same performance as the 1/4 inch measurement.Jaw dropping performance figures! Can we get an XLR/balanced output power measurement at 300 ohms? Also do you plan to do any listening tests with it?
What is sad, really, are companies asking so much more for likely so much less. In any case, in the scheme of things, this is much cheaper than, say, the Sennheiser HE-1... but you don't get fancy marble and a lot of tubes.
I did listen. It is in the review. 300 Ohm results are also there as there is no electrical difference between XLR and 1/4 inch on the HPA4. XLR connection simply separates the shared negative wire for the two channels. Otherwise it is the same as 1/4 (i.e. no increased power).Jaw dropping performance figures! Can we get an XLR/balanced output power measurement at 300 ohms? Also do you plan to do any listening tests with it?
I played extensively with that. Differences were actually small. At the end, I did settle on using sweeps to a bit over 11 volts. I used the same with the THX amp by the way which allowed a fair comparison.I don’t recall what input signal level you use when measuring devices like these, but if you use normal consumer device level, I note that the Benchmark DAC3 and the HPA4 can agree to use professional levels (12 or 15 dB higher if I recall their documentation). So that combination should yield even higher SINAD numbers.
Doah you did listen (and I clearly didn't read properly!) I take it this is not a fully balanced amp right?I did listen. It is in the review. 300 Ohm results are also there as there is no electrical difference between XLR and 1/4 inch on the HPA4. XLR connection simply separates the shared negative wire for the two channels. Otherwise it is the same as 1/4 (i.e. no increased power).
It is where it matters which is the input side.Doah you did listen (and I clearly didn't read properly!) I take it this is not a fully balanced amp right?
That's what everybody who ever tried to fix me up with a blind date said.Yes. Some gear is more attractive than others. Accuphase, Lux, McIntosh. But I've got some of this Benchmark stuff, and can report that once you turn the lights off, they all look the same. And after a few beers, it starts to look better.
Here is that measurement:Also an FFT of the 19+20 kHz IMD test like you did in the AHB2 test would also be greatly appreciated.
This is with cable:Could you please do an internal loopback test of the AP at 5.7 volts and one loopback test where you use the same wires as you do for testing the amp?
Hi Amir, may i have some spectrum graphs with load? Like 120mwmw 500W 1W 32ohm or something like that. (of hpa4 of course)This is with cable:
Going internal loopback shaved a hair from this but not beyond the run to run variation.
SINAD matches the Benchmark HPA4 (due to noise dominating) but note the absence of any distortion products visible in FFT.
Pity Benchmark doesn’t offer the 3-year warranty outside the US... Moon-Simaudio does (10-year!). Bryston does (20 year!!).
Awesome review Amir!!!! So there is literally no difference between xlr and 1/4 headphone out? Not even slightly? If so that's pretty awesome.
As the logic goes. It's not traditional balanced output. Just separated ground point. Same as the one in Neurochrome Hp-1.Awesome review Amir!!!! So there is literally no difference between xlr and 1/4 headphone out? Not even slightly? If so that's pretty awesome.
