Standards are important. And the reason for its existence is to follow . But standards are not always absolute. Because standards are always walk slow for reliability. I am working as an audio measurement critic. I have measured the headphone jack performance of Samsung Galaxy and LG smartphones. Since this is a kind of digital-based device, I tried to measure the AES-17 with a few modifications.. However, I have experienced difficult in measuring the load test, and in particular the output impedance measurement has come up with an unreliable value.
Later, in recent smartphones, there is a solution that detect the resistance value at the chip and codec level. This is for to protect the consumer's ear. It was established as the EN-50332 standard. The smartphone searches for the resistance value and recognizes whether the connected device is a line-out, an in-ear headphone or a headphone. And according to the detect result, maximum output is limited to 1Vrms in lineout, 400mVrms in-ear headphone, and 2Vrms in headphone.
Therefore, the actual performance of this unit can not be measured with normal measurement. In order to measure the output impedance, it is necessary to try no-load measurement and load measurement, but the smartphone recognizes the no-load measurement and the load measurement as line-out mode and in-ear headphone mode, respectively, and adjusts the output automatically. Therefore, the output impedance comes out to be a huge value. The method of bypassing this solution varies from manufacturer to manufacturer. As the device evolves further, the standard loses its power. And this is going the right way.
I do not want to admit it, but the measurement by the consumer will lose power. Device will be equipped with various solutions and functions for each manufacturer in the future. This is especially true for smart amplifiers. Klippel and some of the company's patented "smart amplifiers" can detect various information including speaker distortion and voice coil displacement just by being connected to a speaker terminal. The measurement is valid and usable only when DUT is raw . Many devices in the past were raw, so measurements were useful. But not now. And also in the future. Features for the consumer will be added and they make the measurement impossible or unnecessary. But this should not be bad criticized.
The AHB2 is not a smart amplifier, but it is not a completely raw amplifier. As I said earlier, the AHB2 has protection for the consumer's ear or speakers. John siau says that it works in a way that does not affect sound quality. I agree with that. A typical consumer will be completely transparent when using this amplifier. However, it is not completely transparent when it measured by consumer. because they can not bypass protection. But you should not blame AHB2. This is because the protection mode is built for the consumer. Many devices will preclude standard measurements in the future.
There is no need to severe push past standards into the new era.
