Review and Measurements of Benchmark AHB2 Amp
Off topic,
Benchmark now has a pop up on website that allows inputting your amplifier THD+N, output rating, sensitivity of speakers, number of speakers, listening distance, and type of room.
Plugged in my system and got 0 dB noise at 110 dB listening level at listening position. Must be correct. Hopefully will never know.
Off topic,
Link?
I was not able to get link. Go to Benchmark Media and select calculators from drop down. Scroll way down to THD + N Calculator. There are several calculator and conversions above.
Benchmark has always been very sharing. I had a source once that only had analog and optical output. My dac only had coax. Found a tech note on Benchmark website on changing optical to coax. A few resistors and small ceramic caps was all that was needed. Works perfectly.
Good people.
Very interesting twist on the typical analysis. I'd like to see a further exploration of this with other amplifiers, especially tube amps.
I replaced my 30+ year old Mark Levinson 333 stereo amp with two new AHB2's about six months ago, and I was happy with the change. I believe that I heard an improvement. However, I recently tried out a new Bryston 4B3 stereo amp at home and decided to keep it, replacing the dual mono AHB2's (which I still have), and I am also happy with that change.
The 4B3 seems to sound less thin than the AHB2's.
The dollar cost of two AHB2's and one 4B3 are comparable.
The only explanation that I can think of for my preference is that the 4B3 is actually rated to drive a 4ohm load and actually delivers, whereas the mono AHB2 is not so rated and possibly does not deliver as well. My initial AHB2 investigation consisted of correspondence with Benchmark on this issue, and they stated that in spite of not officially rating the AHB2 in mono mode for a 4ohm load, it would nevertheless drive a 4ohm load effectively.
I lieu of having the means to actually measure these two amps for comparison, I must depend on analysis of the published specifications for a possible explanation. And, the specifications for the two components differ in my application.
My speakers have an impedance curve that sometimes dips below 4ohms.
The above curves show the THD+N vs Output level for the AHB2. The blue curve is 8-Ohms stereo. The Orange curve is 4-Ohms stereo. The green curve is 8-Ohms mono.
The horizontal and vertical units are expressed in dB SPL at the listening position. This assumes 90 dB [email protected], 1m. It also assumes a 2m listening distance in a "typical" listening room. You can easily adjust the values of the X and Y axis by a few dB if your speakers have a higher or lower sensitivity relative to 90 dB.
From X axis above, we can see that with this configuration, we achieve 110 dB peak SPL in stereo and 116 dB mono. From the Y axis we can see that the noise floor is -117 dB SPL in stereo and -115 in mono. This 3dB difference is expected because the two channels are connected in series in bridged mono and the amplifier noise is uncorrelated white noise. Notice that the output is 6 dB higher in bridged mono, so the SNR is actually 3 dB better in mono than it is in stereo, even though the noise is 3 dB higher.
More importantly, if you look at the Y axis, you will see that all three curves are entirely below the 0 dB SPL threshold of normal hearing. This means that the noise and THD never exceed the threshold of hearing, even when the amplifier is delivering full output (100W, 190W, or 380W). The green curve appears to reach about +4 dBSPL, but this rise is largely caused by the limitations of APx555b analyzer, but that is another topic.
What this graph shows is that the AHB2 does not show an increase in THD when driving 4-Ohms instead of 8-Ohms. This is very unusual. Most amplifiers produce more THD into lower impedances. The graph also shows that there is absolutely no audible distortion. The distortion is below 0 dB SPL which means that it would be inaudible if the distortion could be played while the music was muted. With the AHB2, we are not using the music to mask the THD produced by the amplifier.
Just to provide a bit of context, here is the AHB2 response with that of 6 other top-rated amplifiers. Notice the significant difference in the noise floors and notice the significant rise in THD that occurs with most amplifiers as the output level increases. All of these curves are only showing the 8-Ohms response.
And, to provide a bit more context, here is what happens with many amplifiers when driving 4-Ohms vs. 8-Ohms:
Notice how the THD is 5 to 10 dB louder when this amplifier is driving a 4-Ohm load. Also notice that the THD is 40 to 50 dB above the 0 dB SPL threshold of hearing. With this amplifier, you would need to hope that the music masks the THD, because it is louder than normal conversation.
I have just written an application note on the topic of plotting THD+N in terms of dB SPL. This plotting method makes it easy to see the noise floor, the SPL of the noise, the SPL of the THD, the peak SPL of the system, and the differences that are caused by changes in impedance loading. None of these can easily be extracted from a traditional THD+N % vs Power graph, but all of the data is there and it can be extracted and replotted in THD+N SPL vs Output SPL.
Here is the link to the paper:
How Loud is the Distortion from Your Power Amplifier? - John Siau, Benchmark Media Systems, Inc.
I’ve seen a few posts complaining about the size of the AHB2 and other Benchmark components. Personally, I was looking for gear with a small footprint. My old amps were monsters—around 90 pounds each and huge. The AHB2’s compact size and light weight are a big plus for me. They sit neatly behind each speaker and stay pretty discreet.
Off topic,
I got the same. Amp is a 30 year old Krell.
Old ain't always bad! However, the AHB2 remains on my short-list of recommendations for people who want a fully transparent new amp. There are a couple others that have very low THD+N across the power range, but very few have the build quality and industry reputation of Benchmark. John Siau really does have a winner here.
A strange question.
Love listening to music on high volume (weekly sessions at least). Currently my setup
- Topping DM-7 (8 channels DAC, 4 channels in use) + Mac book as source (Apple Music / Roon etc)
- Buckeye NC252MP amp
- KEF R11 (non meta)
- Dual Subs (Monolith THX 12 Ultra)
- Dirac Live with Bass control
- Some acoustic treatment in the room (self made panels etc)
I started thinking about upgrading my AMP from Buckeye NC252MP to ABH-2 state of the art AMP.
If we put aside insane price for the AMP (with tax it is about $4K), will I get any objective improvements in my experience? Or it's already deminishing returns and there is no reason to move to 4K AMP?
from my experience I have no issues with dynamic range or with power, and I for sure do not hear any THD (subjectively). So I should not upgrade I guess?
I'm waiting for a suitable Hypex or Purifi replacement for my Parasound HCA-3500 (350w@8Ohms). I want a class D amp between 600w and 1000w @8Ohms. My Parasound works like a dream, but is 19" x 19" and weighs 85lbs so I know exactly what you mean.
I also want to replace my HCA-2205 (220w@8Ohms x 5channels), but there are suitable Buckeye amps for that one.
Is it possible for an amp to gain weight with age?
A strange question.
If everything is functioning properly you should hear no difference. I'd wager that the AHB2 will last longer and be more reliable.
Nicely chosen setup btw, that should sound great!
I have turned into a grumpy old man. Wanted an AHB2 almost since announced. Never pulled the trigger. Found a used once once for 1600.00. Plus tax and shipping. But a new one was 2300.00. Decided to just buy new.
Doubt John will update these, unless something like supply of output devices dry up. It is amazing that these were the lowest noise commercial amplifier for so long. So overbuilt.
If I needed more power than I have, would already have an AHB2. For whatever reason, a Hypex or Purifi based amp has never been considered.
I have switching amps. But like the favored ones I have purchased or owned are Class AB with resonant mode power supply. Or today’s Class B with simple brick.
For my needs a Micromega had plenty of power. But a 200.00 TPA3251 amplifier sounds better. More bite, bass control, and more live sound. The French amp is too polite, too soft.
This is heresy here, but amplifiers that measure almost the same can sound different, a little. And amplifiers that measure very differently and can sound the same. Lot of variable's.
Like a Purifi based amp, the AHB2 was designed to have no sonic signature. Think both succeeded.
