Review and Measurements of Benchmark AHB2 Amp
RichB
Massachusetts
My Prima Luna Evo 100 has a gain of only 10.8 db and I can’t change it .. I will try to change my gain in my Chord Qutest DAC …
It is easy to get used to the volume indicator on the source. When comparing, even when not using A/B, it is best to level match. The louder source generally is perceived as having greater detail. I'd start there.
- Rich
Sal1950
The Chicago Crusher
Central Fl
I’m stuck !!! I upgraded to the AHB2 from a Peachtree Nova 300 I was running in power amp mode … I was expecting a upgrade but I feel like my soundstage isn’t as wide and the details not as good … while listening to Bill Evans live at the Vanguard I could hear the drummer hitting a snare also can hear the people talking in the background while using the Nova … same album same song and I can no longer hear those things thru the AHB2 … everything was the same in my setup except the amps …
Solid State Amplifer design has been a solved problem for 4 decades or more. I believe where you disappointment entered was expecting the AHB2 to sound different than the Peachtree. The AHB2 is a SOTA amplifier and offers probably the best measurements available today. But when compared under tightly bias controlled conditions to other modern designs, any differences will be extremely subtle if they exist at all.
If you read Amir's review of the Peachtree you will see that the amplifier section offered very good performance.
If your interest is hearing exactly what comes from the source, you might have been better off just listening to the Peachtree alone, though it's DAC section is a bit off. Many Tube preamps are known to alter the sound of the source, maybe you like the way it's alters the sound and that's fine. But as I mentioned, if you want to hear exactly what's on the source, a Solid State preamp would likely offer more accurate reproduction.
Get yourself a Benchmark LA4 to replace the PrimaLuna and you will have world class SOTA playback.
BTW, you may not like this answer, but expensive power cords are worthless.
Bobo75
I was using the Nova in power mode only and bypassing the pre and the Nova DAC … thanks for the thoughtful reply and I appreciate it
Wino
I was thinking of getting a couple of these to pair with Holo May and Dynaudio 360 speakers. I wanted two as the Dyn's are 4 ohm and like a lot of power. Is it true that you cannot bridge these with 4 ohm's?
Wino
Thank you. Nice review and very nice speaker. I was also considering the NAD C298 and the ATI 6002. Did you find a big difference between the C298 and the Benchmarks?
Kal Rubinson
Industry Insider
NYC
misterdog
That said, anyone who thinks that the Benchmark is a *perfect* amp because of its steady state measurements will learn that that doesn't yet exist.
I've owned an AHB2 for several years now, and it's the cleanest amplifier I've ever heard. I was listening to it last night and I can only describe the sound as ravishing. Like silk. Or like Class A without the absurd size, weight, and heat. (If you've ever heard crossover notch distortion you know why Class A amps sound better than A/B ones, it's incredibly audible and annoying in small amounts.) And the low weight, tiny form factor, and efficiency of the AHB are really welcome. It's a save-the-planet kind of amplifier, without the sonic compromises of Class D.
But perfect amplifier? No. It excels in steady state measurements, but it isn't as dynamic sounding as other good amplifiers with which I've compared it. Again, this isn't a question of steady state measurements or amplifier power -- I'm not clipping it. But listen to a piano on the Benchmark and another good amp and you'll hear what I mean: it rounds off the attack.
Amplifiers actually differ surprisingly in the degree to which they do that. My Parasound A21, for example, is a less refined amplifier than the Benchmark, but it happens to be one of the best amps I've heard in this particular regard. There are those who say that the Benchmark robs music of excitement, and after several years of listening experience, I tend to agree. It's strength is in beauty of sound. The highs in particular are to die for, like gossamer.
Another issue is, paradoxically, lack of distortion masking. Lower order harmonic distortion is known to render higher order harmonic distortion euphonic. This is because of the mechanism by which we detect the timbre of sounds. And higher order distortion is unfortunately quite common on poorly made recordings and badly-designed equipment. What this means in practice is that the AHB2 will sound great on clean recordings, but will pass the harshness through on more distorted ones, while some more colored amplifiers with lower order harmonics will tend to mask that harshness.
So the Benchmark isn't a perfect amplifier, but anyone who has never heard a really good amplifier or thinks that all amps sound the same is going to be blown away by the sound. It's a bargain, too, by the standards of high end amplifiers, and with its sophisticated protection circuitry, quite bulletproof!
From a poster earlier in this thread.
I've highlighted one particular part, though there are some who will argue that class A/AB and D must all sound the same if they measure the same.
Sal1950
The Chicago Crusher
Central Fl
I would challenge you to identify these amps from each other in a bias controlled DBT.
They all have their "special" sound when you have your eye's open.
darkless
Denmark
Any recommendations for a great amp that can deliver those dynamic piano transients? As a Benchmark AHB2 owner myself I'm always interested in learning more.
Wino
Close to pulling the trigger on AHB2 x 2 and Holo Serene to pair with Holo May and Dynaudio's.. I already own the May and Dynaudio's, so not looking for thoughts on replacing those. Thank you. I get 30 day trial with the Benchmark's and will compare it to a NAD c298 that I can borrow. These would replace a Krell Integrated Amp.
dlaloum
Interesting...
Your characterisation of the AHB2, is similar to my own long term feelings about the Quad 606 & 707 current dumping amps
Both the AHB2 and the Quads share the base design of current dumping / Feed Forward, I wonder whether the sonic similarity is due to that.
The Crown XLS2500 that I have in the system now, handles the speakers better as they are a bit of a difficult load - this is totally subjective - but it feels as though it has better dynamics (perhaps a response more to the spec sheet than the sound?) - I probably should redo my long term comparison with the Quads now that I have Dirac EQ in the system.... some years back I recall thinking the Quads sounded "sweet", with more microdetail in the mix.... where the Class D crowns focused more on clarity and dynamics. (could I tell them apart "blind" - probably not - but there are still observations of how I felt about the sound after a couple of months of one or the other.... - I will plan for a swap over sometime later this year)
Wino
I put my order in for two AHB2's today. I am still in need of a preamp. Has anyone compared to Topping Pre90 to Holo Serene with the AHB2? While the Serene would look nice with the Holo May, not seeing a reason for the extra dollars over the Pre90.
Sal1950
The Chicago Crusher
Central Fl
No hands on myself, but to quote from Amir's review,
"It is an instrument grade, more transparent than transparent, preamplifier. Other than Benchmark HPA4, I don't think it has an equal no matter how much money you spend."
What more can be said unless some non-performance based feature is important to you.
PGAMiami
I’m using 4 AHB2s, all bridged in an active biamp. No preamp, just a Meitner MA3 DAC and a Pass XVR crossover. It sounds fabulous, detailed, huge dynamic range, no distortion what so ever. This replaced much more expensive Constellation Centaur monos. For me these were an improvement and the best of a long series of much more expensive amps, including Spectral, Pass, Cello, Levinson and MSB.
RichB
Massachusetts
Interesting...
I have compared the AHB2 to my Sunfire Cinema and also to the ATI AT525NC using and A/B speaker switch for instant switching.
I used a MiniDSP SHD USB that with the main channels duplicated and level matched to .1 dB using DSPs. The levels were matched using a Fluke 87V voltmeter playing 0 DBFS 1kHz sine waves.
In both cases, the AHB2 had a cleaner upper end, symbols and sibilants were better resolved.
Initially, I did not have the Sunfire balanced, perhaps it was cold when matched, but it was running a .2 dB louder. The result was the Sunfire was perceived to have better bass. Once properly matched that disappeared.
For personal listening tests, proper level matching is a must. It is easy for users to compare using known preamp levels. The AHB2 has lower gain than most amps, even in high gain mode. This will likely be perceived as less dynamic since the loud sounds are simply not as loud until matched.
- Rich
PGAMiami
- Rich
Cymbals and sibilants are exquisite on on AHB2. I’ve only used mine in bridged mode, that said, I’ve also never felt dynamics were limited. Bass slam and control is also exceptional. Mine are driving TAD R1s, that have a nominal impedance of 4 ohms. The AHB2s have no problems at all driving these large speakers with beryllium midrange and tweeters that are very sensitive to bright electronics.
Wino
I decided to pair the AHB2's with an LA4. I like the small form factor and figure it will work well with the AHB2. Mistakenly put my order in for silver when I meant black. Hopefully they can correct it before it gets shipped. Regardless, thank you for thoughts on Topping Pre90.
Kal Rubinson
Industry Insider
NYC
Good choice. I would have gone with the LA4, too, but for my need for 3-4 of them. :facepalm:
