Westsounds
- Joined
- Jan 10, 2020
- Messages
- 648
- Likes
- 463
Hiss can be annoying in a modern hifi. We've become so used to the low noise floor digital is capable of.
Don't even try. I did try it naively few years ago when I had a ddrc24 with hiss in my tweeters.I’ve been using a DDRC-24 for many years alongside a high-gain amplifier. It does produce a faint hiss from the tweeters, which becomes inaudible at a distance of about 30 cm. from the tweeter. In the thread, I came across someone who reduced the noise by replacing the power brick. I’m considering trying that out, purely as an experiment.
I probably would. But only if I have one in my workshop.Don't even try. I did try it naively few ago when I had a ddrc24 with hiss in my tweeters.
Didn't make any difference (as expected).
Replaced it with a flex and hiss went away.
In my case, hiss was audible up to 1 meter (94 db sensitive speakers at that time, replaced since).I probably would. But only if I have one in my workshop.
The hiss is inaudible 20-30 cm. away from the speakers anyway. It's not detracting anything from the dynamic range...
That's great, thanks so much for sharing! If I had speakers as sensitive as yours, I definitely wouldn’t have held onto the DDRC-24 for as long as I have.In my case, hiss was audible up to 1 meter (94 db sensitive speakers at that time, replaced since).
After few back and forth with minidsp support back in 2022, I was left with no solution. It was not even an issue with gain structure.
While not be being an issue at MLP it was annoying me.
I naively tried (without having much expectation) a better linear power supply. Did not make a single difference (of course).
Then I decided to get a Flex instead (to be used as a proper preamp with display and volume control).
While there were no audible difference in audio quality (as expected), the hiss completed disappeared, even with ear against the tweeter in same setup and environment.
And since, I replaced the Flex for a Flex HT that allowed me to get rid of my AVR for my mixed 2.2 (music) and 3.2 (HC) setup using the Flex HT as a multichannel preamp/xo/drc pro and existing power amps.
Oh, so that’s what they refer to as a "revealing system" over on Audiokarma?I have a main question to every Equalizer expert here...
Background... I am now using a truly excellent Yamaha GE-40 equalizer (which offer 10 stereo band with red diods +-15db 110dbAihf 0.005% 10-100khz made 1985-86) to adjust bad recordings before I save them on one of my Sony MDS-JB730QS
(my complete stereo scourse setup is - Sony CDP-XB720 cd player / Pioneer BDP-LX55 bluray / Tuner via Zone 2 from my Yamaha Receiver / Sony 75 inch TV / Denon DP-37F turntable / Acer notebook via SoundBlaster THX pro > Denon PRA-1200 preamp > Yamaha GE-40 "recording adjust" equalizer > Sansui SE-77 "headphones" equalizer > Yamaha RX-A1030 av receiver > its parametic equalizer, that I use as main playing eq > plus Yamaha's 7 channel setting > three Cerwin-Vega AT100 modified for TMT configuration & two cute Klipsch as back speakers)
But the sublime GE-40 is almost 30 years old now and may naturally die tomorrow, so I wonder about the best alternatives under 400 euro used or new...
And yes I especially love that it have Stereo sliders (just as the following alternatives) so I don't have to adjust every band twice for right and left!
- miniDSP 2x4 HD?
- The extremely rare and at least 15 years old Behringer DEQ1024 (31stereo +-12db bands from 20hz to 20khz, it has also mono > stereo > wide adjustment, 2st 12 led meters, handle 15-35000hz S/N -104db within 22hz22khz 0,004% and international power supply) ??
- Behringer DEQ2496 UltraCurve pro??
- A very old Yamaha YDG2030 studio equalizer (parametric slim black 20bit 44.1hz +-12db 30 band 40 memories S/N 106db 0.007% only XLR connections) ??
- Something that is even better, under 400 euro used???
Any advice is naturally warmly welcome!
New member - Björn Blomberg
It will probably be a few dB better. A higher signal amplitude compared to a constant noise level will result in a better Signal-to-Noise Ratio. Other parameters like THD, IMD etc. need to be measured in both cases using an audio analyzer to get the answer. This is not so critical for subwoofer frequencies (from 20 to 140 Hz), and as previously tested, the human ear is unlikely to detect any harmonic distortion in this range unless it exceeds 10%.Given that the ADI-2 can output pretty high levels, would the mediocre performance of the 2x4HD improve a bit with the higher 4V input sensitivity?
Got it. My ADI-2/4 Pro SE has an optical (digital) output which I sometimes use to feed the signal to subsequent DACs with ADI-2 volume/EQ/loudness pre-processing.I am using the RME ADI-2 DAC FS...
The ADI-2 does not have a digital output, so I would not know how I could connect the subs differently and still use the various features of the ADI-2.
