• WANTED: Happy members who like to discuss audio and other topics related to our interest. Desire to learn and share knowledge of science required as is 20 years of participation in forums (not all true). Come here to have fun, be ready to be teased and not take online life too seriously. We now measure and review equipment for free! Click here for details.
Review and Audio Measurement of LG G7 ThinQ Smartphone
Rod
Patreon Donor
So maybe a user should consider matching the headphones to the amp if carrying adapters and seperate amps isn't wanted. V20's are cheap on ebay if you dont need band 12(t-mobile).
Pipps
The cable (which has its own DAC and amp) will decode the Bluetooth signal. The quad DAC means nothing in this instance. The only thing you'll have control over, is what format you send the signal over Bluetooth (which means you need to know what formats the cable can handle, those such as SBC, AAC, apt-X, apt-X HD, LDAC, etc).
EDIT: Since I see now that it supports apt-X, I would just go ahead and use that.
Assuming source material in FLAC 320kbps format [Edit: As APT-X is limited to 352kbps], [Edit: Plus a reasonable pair of IEMs such as the Westone W30s], would there likely be any noticeable difference in sound quality between the G7's quad DAC and the DAC inside the Westone Bluetooth cable via APTX?
Sythrix
I was unable to tell the difference when I had a good apt-X signal on my Mee audio BT MMCX connector... However, it was incredibly easy to get dropouts while I was running, which made me rethink my whole strategy.
Generally, the quality remains decent until the signal drops.
Pipps
Try an AGPTEK Clip on your waistband whilst running - practically no movement so constant Bluetooth connection :)
[Edit: Thank you for the confirmation on sound quality.]
The G7 has a similar dac setup to the V20. How would you rate the G7 if you can only use it in a nonbitperfect setup?
I would use it as a DAP only (V20 are under $200) with the adapter for the external mode. I just would either use Spotify, or my local library on MediaMonkey/RocketPlayer (I need it to sync to my library on my PC to record playcounts/etc.)
It's this or save up for the HIby R6, assuming that's a significant upgrade.
In non-bit-perfect mode, your SINAD drops to below 96 dB. So you give up fair bit of performance but audibility may be similar.
That answers that then. I guess I'll save up for the hiby r6, think you'll review that dap anytime soon haha
@amirm
Did you ever test the Lightning dongle?
I did. Got two actually. :) One I bought and another was kindly sent with an iPhone 7 to test with.
bigx5murf
I've owned every LG-Vxx phone up to my current v30, and there's a simple way to get around the power limits with lower impedance headphones. You just use a 3.5mm extender, and plug your headphones into that. In the v10 and v20, it actually tells you which power mode it's in. Normal is the anemic one, AUX mode is significantly more powerful (what it goes into with the extender), and high impedance mode is slightly more powerful (goes into this with headphones higher than 55ohm). I'm kind of bummed they removed the feature of telling you which mode it's in.
I do want to add, I had major reliability issues with both the v10 and v20. Both were replaced under warranty multiple times. The excellent audio performance kept me coming back to this series. No other phone could get volume loud enough when I was at the gym.
Whenever you get a chance again with the phone could you test rocket player? I saw a list of apps that are supposed to bypass android and it was way more than neutron and uapp the two that everyone like to recommend. I need sync to my iTunes and the majority of the apps are phone only when I like my data to be shared.
I'd ideally use media monkey on both but I don't believe media monkey on Android bypasses the Android audio system.
