And the only floorstanders in his selection. Thanks for pointing this out. Appreciated.He did recommend them in his "Top 5 Speakers at Any Price Video" as of 1 year ago though.
also, he reviews a LOT speakers as do Amir hereAnd the only floorstanders in his selection. Thanks for pointing this out. Appreciated.
The snare has an excellent ‘paper sound’ timbre to it.
Might be worth to go for a listen, sadly their price list for the 226 is out of my budget, nearing 10k.Check https://www.referencesounds.nl/en/ , they carry amongst others Revel
Search: 22 results found for "revel"
Established in 2008, Nintronics Audio is a specialist retailer and installer of High Fidelity Music and Home Cinema Systems.nintronics.co.uk
Not in EU, but close enough. They have great price on 228s that could fit your budget. Did not do business with them but they seem very responsive. Was looking into 328s but still can't decide.
Also found these that might be closer to you. Have never heard or dealt with the seller though.
Revel F 228 Beryllium (3433908697) | Neugerät | Standlautsprecher | Angebot auf audio-markt.de
Angeboten wird „F 228 Beryllium“ von Revel als Neugerät aus der Kategorie „Standlautsprecher“ bei audio-markt.de - dem Online-Marktplatz für High-End. Das Inserat mit der Nummer 3433908697 endet am 24.04.2025 um 06:53 Uhr.www.audio-markt.de
Honestly I fail to understand why audio companies allow situations like these... how can the same exact product cost twice as much in Europe compared to the UK?Don't want to risk shipping from overseas in case I need support in one way or another. But if that's the set price it is very good indeed.
this is for a pair & new, as mentioned in the listing -> https://www.audio-markt.de/market/revel-f-228-beryllium-3433908697 hardly it is discounted from 11k for one piece..Honestly I fail to understand why audio companies allow situations like these... how can the same exact product cost twice as much in Europe compared to the UK?
I'm assuming the £3,999 price is for the couple, considering they say it's discounted from £8,399. Whereas the price for a single speaker in the Netherlands is €4,899 (and the center speaker, C426Be, is an eye watering 5,999). It would sound like a joke if it wasn't sadly true.
What is the difference between a fast and a slow subwoofer?Moved to a new house with my dedicated audio room being 16x12x8. I have all the bass traps/1st reflection panels and diffusers in place. I was trying to get my large Ushers to work in this room with no luck. I ended up with the Revel F226be speakers. These speakers are perfect for the room whether I use Jim Smiths speaker positioning method or the typical 1/3 or 1/5 into the room method. The f228be’s would be too big. All my audio g up members indicated I don’t need a sub with these on most music I listen too. I have been demoing my system with a small NHT subwoofer/controller I have and with its 10” woofer, with it crossed over at 60 with high level inputs, with the volume just barely on, it gives the speakers a better fullness, better bass definition. I’m probably going to get a pair of Rel T5x subs to compliment the 226be’s. I don’t need much more bass and the t5x subs are fast and down to 30hz.
About 4”-7”! I’m in the camp that likes multiple smaller woofers than 1 bigger 1, so 8” woofers are my sweet spot. I rather get the Revel Salon 2 with multiple 8” woofers over say the Usher be20 that has multiple 11” Eaton woofers.What is the difference between a fast and a slow subwoofer?
It’s amazing that an unequivocal post by Dr. Toole on a given audio related topic can be linked and it will still be ignored in the following replies. Like there could be any further discussion on „fast“ vs „slow“ bass.A comment on the subject of fast bass vs. slow bass ...
A Broad Discussion of Speakers with Major Audio Luminaries
It is resonances that are mainly responsible for lack of neutrality in loudspeakers, so the first task for competent speaker designers is to minimize them. After that spectral balance and directivity control need to be attended to. The industry standard measurement method, used by Amir, which...www.audiosciencereview.com
Well that's not going to take off on this forum anytime soonBS on measurements. My ears are the only measurement tools I need.
This may not be the most satisfying place for you.BS on measurements. My ears are the only measurement tools I need.
