- Joined
- Mar 30, 2019
- Messages
- 1,202
- Likes
- 2,101
It doesn't look too bad, at least crossover wise. It would be nice to see it more zoomed in. Try to the 10-200 option. Are you using DSP? If so what are your settings? Full range? I ask because I don't see any major room modes. If so, which DSP system and which curve? For my taste the bass is either is set a bit low volume wise or integrated low if DSP is used. Are the speakers far from the wall? As I don't have too much info it seems that the if there is DSP the curve being used is rather flat. The problem doesn't appear to be the crossover but I'd love to hear other opinions. Look at Amirs measurements to see an how the Harman curve sort of looks like, which has a downward slope. I forget but it may be something like -10 dB across the range but down quote me on that. Dirac uses something similar with a slightly bigger slope, maybe 1 or 2 dBs more. If you can add a curve to your DSP perhaps Harman is available.Thanks. This below is the measurement at 80 crossover. I'm not an expert at reading these charts.
