Revel M16 vs Elac UniFi Reference UBR62
Ziroz
Both are available to me for a similar price, I intend for desktop use only. They are similarly sized, the main difference is that the M16 is a two-way and the UBR62 is a three-way. Which one would you recommend?
Revel M16
14.75" x 8.6"x 10.76" (37cm x 22cm x 27cm)
1" Aluminum Tweeter
6.5" Aluminum Cone Woofer
lac UniFi Reference Ubr62
14.13” x 8.19” x 13.15”(35.9cm x 20.8cm x 33.4cm)
1” Soft Dome Tweeter
4” Aluminum Midrange
6-1/2” Aluminum Woofer
Or, you could lightly PEQ your M16s like I did with my RME ADI-2 DAC FS and they sound amazing.
