Alice of Old Vincennes
- Joined
- Apr 5, 2019
- Messages
- 1,726
- Likes
- 1,142
Ohhh come on.There have been a few amazing inexpensive speaker amps tested here lately, starting from $100. Pick one that fits your budget.
Meaning what exactly?Ohhh come on.
Which test parameters do you feel prevent the recent lower priced amps from performing well with the M16?Ohhh come on.
Bookshelves are I efficient and need more current. Makes no sense to mate Revel with $100 amp.Which test parameters do you feel prevent the recent lower priced amps from performing well with the M16?
Did you try plugging the ports?I've got a pair of Revel M16s....they are a fine speaker. I use them in a nearfield position to stream Tidal....they do have a huge soundstage, great mids and non-fatiguing highs.....however I find the bass to be over accentuated and not especially tight. As a result I think they were probably designed to be a home theatre speaker....seeing the frequency response chart aligns with my experience....
I drive them with an old pioneer 50 watts Class A/B amp.....I do notice the amp struggles with bass heavy tracks....but I think that probably has to due with the limited amount of capacitance (2x 10k uf) the amp has to offer.
I'd suggest to try room EQ - a few bands of subtractive PEQ should solve the issue and in general greatly improve sound quality (with any loudspeakers).I've got a pair of Revel M16s....they are a fine speaker. I use them in a nearfield position to stream Tidal....they do have a huge soundstage, great mids and non-fatiguing highs.....however I find the bass to be over accentuated and not especially tight. As a result I think they were probably designed to be a home theatre speaker....seeing the frequency response chart aligns with my experience....
M16 is designed to sound good for music or home theater. Bass issues are most likely placement. Also, small speakers are inherently inefficient and need lot of power.Yes, I did will negligible results.....my listening room is 4.6x3.1m with some diffusion only......so I'm conscious it could just be the room more than the speakers...
What is obvious? You mean the bump from 50 to 100? That was intentional and is easily eq'd.
On the other hand I now see the M16 bass hump as free headroom for subtractive room EQBecause it was intentional doesn't make it accurate. It's still exaggerated FR.
interesting, could you show the before and after EQ results?I've been using RoomEQ wizard to calibrate the FR via EQ APO.....I've had great success with this in the past, but it hasn't helped with my m16s on this occasion.
However, I'd like try these speakers in a bigger room to see how much my current listening room is a factor...
The measurement looks a bit strange to me (I also own and use the M16), may I ask:GREEN = PRE
BLUE = POSTView attachment 312801
