dominikz
- Joined
- Oct 10, 2020
- Messages
- 972
- Likes
- 3,141
I don't think my home office will ever be audiophile nirvana, but the main problem was definitely down to a room mode issue rather than anything specific to these speakers. Just setting -12db at 125hz in Foobar2K's graphic equalizer DSP has tamed the bass that I found so unpleasant on certain tracks. Obviously I'll fiddle and tweak a lot more than that, but I think these are definitely speakers I can live with.
I'd heard about room modes before, but this is the first time I've actually heard the effect they can have. For some reason I had the impression that it was something subtle that you'd only hear when carefully listening, rather than a big change to the volume at certain frequencies.
I think I've been lucky to avoid this before. Maybe having more clutter and less space actually helped to prevent that specific problem? Or maybe the speakers I was using were just so anaemic at those frequencies that I didn't notice.
You were indeed lucky if you were able to avoid unpleasant room mode and room acoustic issues - they are IMHO one of the worst offenders when it comes to sound quality - much more so than any component swaps IME, even speakers, once you get to anything reasonably well-measuring.
Another (probably stupid) question, but would it be a really bad idea to run the M16s upside down, with the tweeter at the bottom?
FYI, I think I have a similar situation as you - Revel M16 sitting close to a wall on a cabinet that is ~1m tall, the tweeter is above ear level (~6-7 degrees, I estimated). And I did just as you proposed a week or so ago - tried to flip the speakers upside down (which brought the tweeter relatively close to ear height) and then did some MMM measurements at MLP (this is with grilles on):
The results didn't seem significantly different so I abandoned the idea, at least for now. The area around 5-6 kHz even seemed a bit worse with the speakers flipped.
