If you want to continue, start a new thread or take this to one of the many existing threads about whether or not amps sound the same when operating within their limits. This is not the place, and I will not respond here any more.
I’m sure they won’t sound the same but which one is the correct one?Yes I have. I like and agree with a lot of stuff here, however there is a lot of evidence what I am saying is true as well. This is not the only forum or group I learn from.
However, would you say the Aiyima A07 sounds the same as a McIntosh? Just a simple yes or no.
Thank you. I am not going to pursue anything further.If you want to continue, start a new thread or take this to one of the many existing threads about whether or not amps sound the same when operating within their limits. This is not the place, and I will not respond here any more.
Matching with a voltmeter at the speaker terminals is best practice, but here's another protocol that doesn't require matching at all:Level matching with a phone SPL meter isn't good enough, if you want to be truly accurate about your comparison. Those differences that were "very, very small" were probably due to small level differences or other factors as you described.
I suspect the primary reason will be affordability to the purchaser (plus ego, cool factor, impress fiends, etc.) between these two. I did have an Aiyima and though much better than I thought it would be it clearly felt a bit flat compared to a Denon I tried at the time.I’m sure they won’t sound the same but which one is the correct one?![]()
Not necessarily. It's likely to be a disaster.Crossing at 250 is a disaster.
This is very true. And this is the problem of integration subwoofers with a small standmount speaker. This m105 has one of the best 5 inch drivers one can buy, but its not the best below 150 Hz.This depends on your definition of "best placement." I have dual subs under my M105's as well in my near field setup. I can hear where my subs are located with an 80 Hz crossover when listening to music. Having the subs anywhere other than under/inline with the mains in my near field setup sounds worse, because the lower bass is not coming from the same space as the mid/upper bass, and I can hear it. Measurements mean nothing here, because it's a subjective human experience. It's not just frequency, it's location as well. I think that subs that are balanced in line with the stereo image sound better and more natural when listening to music, even if you could get the frequency response to measure "better" somewhere else in the room.
Yes, they would, but...Would the la 90 discrete drive these speakers ?
Please provide the data for this "evidence" - I'd like to see some statistics and analysis. Anything else is just opinion which has no objective value.Yes I have. I like and agree with a lot of stuff here, however there is a lot of evidence what I am saying is true as well. This is not the only forum or group I learn from.
Revel suggests 50-120 watts on these. So you'd be on the lower end. These also have a moderately challenging impedance curve so something with some extra current capability would be a good idea. The LA 90 would probably do it, but like MediumRare said okay in a small room, in a bigger room maybe marginal. The LA 90 is 40 watts into 8 ohms and 70 into 4 ohms. If you already have one, you can give it a try and see for yourself. A bridged pair would do the job, but then you are in a price range with lots of options.Would the la 90 discrete drive these speakers ?
Thank you, Amir for the analysis. I wonder what could happen if distortions were measured at a harmonic where 2 or 3 fundamentals meet. For example, you have a superposition of the fundamentals in a chord.I am not clear on your request. Rescan of what? An EQ? What good would that do other than show the simple effect of the EQ?
I use a Topping PA5 (48w @8Ω / 83w @4Ω). Works like a charm!How would folks say these speakers fare with a 70wpc into 8 amp? Seems to be on the lower side of their recommended power range.
It depends a lot on how loud you like to listen to music, will you have a powered sub for the low bass, what is the handling characteristics of the amp. The odds are 70WPC should be more than adequate.How would folks say these speakers fare with a 70wpc into 8 amp? Seems to be on the lower side of their recommended power range.
No subs and no plans for one, listening in the 60-70db range. I have the Denon PMA1700NE.It depends a lot on how loud you like to listen to music, will you have a powered sub for the low bass, what is the handling characteristics of the amp. The odds are 70WPC should be more than adequate.
I have an Arcam SA20 @ 90WPC and have tested the speakers on an 80WPC Cambridge CX81, a 75WPC Marantz NR1200 @ 75WPC and for grins, an Aiyima A07 amp (50ish WPC) and there was not any substantial difference as to volume ability. I likes the Arcam sound the best but I attribute that to their Class G amp design.
Do you have a specific amp in mind?
Very nice amp - should be able to handle those speakers just fine IMO.No subs and no plans for one, listening in the 60-70db range. I have the Denon PMA1700NE.
Yes, there would be a big difference upgrading to either the M105s or the M106s. Your choice between the two of those in my opinion is based on the size of your room and how close you will be to the speakers. The 105s are also quite a bit smaller, but there is only a few hertz difference in the bottom end. I have three sets of the M105s, and I actually plugged the ports (with the proper included foam plugs) because I have to place them only a few inches from the wall and there was too much bass!Hi all,
I have the opportunity to buy a pair of M105s or M106s in very good used condition. I would be driving these with a Peachtree Audio decco65. Currently I have Q acoustics 2020s connected to this amplifier.
Would a pair of M105s or M106s be a sensible upgrade to the 2020s, and would there be a big (audible) difference between the M105s and the M106s?
