Alice of Old Vincennes
- Joined
- Apr 5, 2019
- Messages
- 1,687
- Likes
- 1,113
Is that hot water or steam heating?Hello ))
just for comparison installed M20 instead of F36. Curtains are already chosen
M20 like a warm comfortable Mediterranean sea water in SemptemberIs that hot water or steam heating?
Hello) This is the most true amp!!! Shit in shit out (c) After 40 hours of listening my F36 is singing like never before. So full, so clear, bass is exceptional. No boom, no box sound!! Mid and high the best!Hello ))
The last upgrade! AVM Evolution CS5.2
I found at Audio Lab (online) outside Philly. Looks like I got the last matched pair.Where are new F35s still available?
Nice. I thought those had disappeared from the channel entirely at this point.I found at Audio Lab (online) outside Philly. Looks like I got the last matched pair.
Amir wrote, "Impedance drops to near 3.5 Ohm so you need a beefy amplifier to drive this speaker"Just picked up a pair of new F35 to try in home. Sounding like they while stay a while however, I am a bit concerned that my Denon X1800H lacks oomph (per Amir review).
lol subtle is... well.. a subtle description. My "current" fronts are actually Wharfedale D330. I have the Dali O5 and Revel here to try vs each other. My plan is to pick one of these two (but I don't have to as I can return either/both). Aesthetics and build quality aside, the Dali sound great for a small and light tower.Your Dali Oberon 5 look very subtle alongside. I always like those whenever I’ve encountered them.
Oh, I see. Well the Dali seem very tolerant of amps and source material, which is why they were always an easy recommendation. And just enjoyable ime, though I’m not sure what the measurement for that is! Bear in mind their successor (Sonik) has been announced so discounts must be incoming.lol subtle is... well.. a subtle description. My "current" fronts are actually Wharfedale D330. I have the Dali O5 and Revel here to try vs each other. My plan is to pick one of these two (but I don't have to as I can return either/both). Aesthetics and build quality aside, the Dali sound great for a small and light tower.
The Denon is completely fine, plenty "beefy".Amir wrote, "Impedance drops to near 3.5 Ohm so you need a beefy amplifier to drive this speaker"
I'm assuming a Denon X1800H (80 wpc/2) is not a "beefy amp"?
That's correct.I'm assuming a Denon X1800H (80 wpc/2) is not a "beefy amp"?
IMHO, keep the F35's and consider some form of up amp upgrade when finance allows. The used market if full of great amps withI haven't decided 100% to keep the F35 but I'm leaning that way. Needing to add an amp (via pre outs) suited for these speakers might impact my decision; can someone give some specifics on what I should be looking for in an amp? I'd probably shop the used market first. Fwiw my use is 70/30 2.1 music / 3.1 movies and tv. Thank you!
Thanks. Never very loud and 2.1 music most of the time. 3.1 for tv/video content.That's correct.
Are you using this AVR to drive a surround system of 5.1 or more speakers?
I'd avoid using it for driving any more than just the front 2 L&R speakers.
Since it only offers the option of Pre-Out for the front 2, you might seriously consider picking up another amp for driving the F35s, using the onboard
amps for your surround speakers.
For now I'd avoid trying to play things too loud.![]()
