Revel F328Be Speaker Review
I think Gene’s assessment was pretty spot on but it’s not a fair fight as the performaBe is not the no holds barred top of the line flagship. Gene did say over and over again in his video review that the F328Be was an excellent speaker.
What I don’t like about the Perlisten S7t is how low the tweeter is. And they do sound really good but so does the F328Be. Gene just pointed out some “value engineering” that Revel did on the Be line. Reusing the same cabinet as the performa3 was lame imho. I really felt this when I replaced my F208 with the F228Be. I sold my F228Be less than a year later even though from a sound perspective they were as good as I ever needed.
Revel may never replace the ultima2 but for all intents and purposes, I don’t really care. If I ever go to replace my salon2/voice2, I’ll buy whatever is best that fits my requirements and budget at that time. I’m brand agnostic.
Is the Perlisten capable of higher quality wider dynamic peaks IYO?
Revel did a good job with the open soundstage of the performa 3 line, but some listeners prefer the tighter set for the sense of a more etched/detailed presentation as some prefer cans. I was more impressed with the bass from the s7t but didn't think it integrated with the mids as well as revel making me think the revels are easier to set up.
240 Hz crossover and acts as second harmonic filter to mids. Only problem they have is beeming little too much up (need a tall room) and of course sub's (where that crossover acts as a first and more crucial to how we hear).
These speakers are huge and heavy, so just curious how people are comparing? I listened to the 328be's in showroom (plus they have 30 day return policy) but it's not really possible to in-home test i.e. I had to hire guys from dealer to get them moved in. And it was quite the job for them, even with a crew of 3 guys. Yes, I did have a flight of stairs, but just unpacking them is a huge task.
Luckily, the 328be sound great in my room, but basically once I had them I owned them, regardless of return policy. I dread the day when I need to pack them back into their flight cases.
The Perlisten s7t were a different story altogether as I couldn't even find a place in Chicago that could demo. I would have loved to compare the two but not possible.
I don’t think many have done comparisons like Gene who has both speakers. Considering that the F328Be was designed to be a better quality version of the F228Be that can play loud with a huge soundstage, I’m sure they are excellent speakers. I could have lived with the F228Be from a sound quality standpoint especially with subs. Looks are subjective.
If there are any 5 figure+ speakers that are not excellent sounding, how long would they actually last?
I think you can go to their headquarters in Wisconsin about 2 hours from Chicago in Verona. It’s about 2 hours and 15 min from my house (west burbs).
I agree, and I don't think you can wrong with any of these choices, but when you're spending 5 figures on speakers it's nice to demo them. Might just see or hear something about one of them that helps with the decision.
I considered going to Wisocnsin, but could never sync with them for an appointment. Maybe I wasn't properly motivated :)
This is a review and detailed measurements of the Revel F328Be floor standing speaker. I purchased a single unit through our company (Madrona) with kind discount from Harman Sales (I asked for a review sample from the PR group but was told "don't call us, we will call you."). The retail cost of F328Be is US $8000 each or $16,000 for a pair. This makes it the most expensive speaker we have tested to date.
I chose the color black and I must say, this is one gorgeous speaker:
It comes in an exquisite finish with sparkles in it in the top panel:
Even the Beryllium tweeter exudes beautify (in the eye of an audiophile of course):
Here is a closer shot of the speaker itself:
As you see, there are three 8 inch woofers backed by two large ports in the back. There is then a mid-range and tweeter.
I performed over 2000 measurement which resulted in error rate of less than 1% throughout the range. This took over 4 hours to capture all the data which resulted in a 1.5 gigabyte file (imagine doing this work manually!).
Temperature was 60 degrees F. Measurement location is at sea level so you compute the pressure.
Measurements are compliant with latest speaker research into what can predict the speaker preference and is standardized in CEA/CTA-2034 ANSI specifications. Likewise listening tests are performed per research that shows mono listening is much more revealing of differences between speakers than stereo or multichannel.
Reference axis was between the midrange and tweeter (a guess).
Revel F328Be Measurements
Acoustic measurements can be grouped in a way that can be perceptually analyzed to determine how good a speaker is and how it can be used in a room. This so called spinorama shows us just about everything we need to know about the speaker with respect to tonality and some flaws:
This speaker was very difficult to measure in low frequencies. The combination of two ports and three woofers created an overly complex low frequency sound field. The initial runs produced clearly incorrect measurements below 200 Hz. After five sets of measurements and optimization, I dialed out almost all the error. The results show that little step between 100 and 200 Hz which Harman data does not. I suspect with a bit more optimization that could have been filled in a bit more. This aside, for a passive speaker we have excellent flatness of response especially considering how many sound producing elements there are here.
Efficiency is superb for a Revel speaker but do keep in mind that we need power in low frequencies the most and there, we don't have nearly the 91 dB that we have in the upper range. This of course applies to all speakers.
Look at how the dashed blue line (early window) nicely parallels the black dashed green line indicating excellent directivity (direct and indirect sounds match). This makes the speaker room friendly as the reflections don't change the tonality of the speaker much. And also allows easy equalization. Let's look at the sum of important early reflections:
Amazing that all the varying reflections sum to such a smooth response. Putting everything together, we get a prefect predicted in-room frequency response:
It took me forever to measure all the drivers and ports in near-field. Turns out most of them were duplicating each other's response so here is a sample set:
Notice the port tuning down to 30 Hz! This speaker should produce very deep bass. And clean too when you look at these incredible distortion measurements:
Are you seeing what I am seeing? Even at 96 dB SPL, you hardly have any bass distortion. Indeed during measurements, I could hear the most perfect sweep ever of any speaker I have tested. Most of the time I hear the pitch change/distort during the range. Not here. The sweep was so buttery smooth. Yes, that is an objective technical term!
Here is the distortion in absolute level:
I picked 50 dB as a rather arbitrary limit long time ago with speaker after speaker missing that mark in low frequencies. Not the Revel F328Be. With the exception of one frequency, it stays well below that.
Horizontal beam width is very smooth:
Notice how the line in pink is also smooth (-12 dB).
Shown as a contour map, we see the same nice response:
Due to inclusion of a mid-range, the vertical response is also good compared to our typical 2-way speakers:
Since this is a tall speaker, you may want to tilt it down a bit if you are sitting too close to it.
Finally, here is our impedance measurement:
That is a pretty low impedance so make sure you have a good, high-current amplifier to go with this speaker.
There is a small resonance visible but I don't see a sign of it in the frequency response so it must be quite minor.
Revel F328Be Listening Tests
Truth to be told, I measured this speaker weeks back. But then it sat in the garage because I could not figure out how to carry it to our loft to listen to it. I almost post just the measurements but then I thought questions of sound and comparison against my Revel Salon 2 would come from every angle. Asked my wife if should could help me drag it upstairs and she said no way as did my back. Didn't know what to do for a while until I realized there was another option: create a setup in our living room which is at the same level as the garage. So I built a quick system out of Matrix Element i streamer and DAC plus Purifi Amplifier. The picture you saw at the start of the review was the setup except I had the speaker further into the room.
First impression was: "this is the sound I am always looking in a speaker." It sounded very familiar to me as it should. What surprised me though was the deep bass. I had not heard such clean and deep bass out of any speaker I have tested so far. My own Salon 2 speakers produce them of course but nothing I had tested would come close. The F328Be was there. It is a wonderful kind of bass you don't get out of a sub in how clean and integrated it is. It doesn't jump out to slap you in the face. At the same you wonder why you had never heard these notes with smaller speakers.
I ran through my "speaker killer" tracks which are full of these sub bass frequencies and the F328Be produced them like it was an everyday affair. Even at super elevated levels, the sound was exceptionally clean. No hint of bass distortion let alone bottoming out. I could see the triple woofers moving but no deep excursion to make them distort.
The one sensation you should know about is that these are tall speakers. When placed too close to you, the voices sound like they are way above you. In a way this is a natural presentation of the size of a singer. But at the same time, you don't want it to keep reminding you so. Push them out and this effect reduces.
I actually listened to the F328Be out in the open first before pushing it into the corner. The latter did cause a bit of boominess due to room mode. I don't have current measurements for our living room so I did not try to dial them out. It is the nature of speakers that play low that they excite room modes more, requiring DSP correction for best sound.
So do the F328Be speakers outperform my Salon 2? With no ability to listen to them in the same spot, I can't say for sure. I can say that at no time I wished I had the F328Be instead of my Salon 2. Its sound simply asymptote up the level of Salon 2 but didn't exceed it. You are spending $6,000 less with 328Be so coming this close is impressive.
In some sense I am the wrong guy to review this speaker, coming from Salon 2. It was impossible to impress me with a speaker with similar tonality and performance.
It was great to test the premier speaker in Harman's newest line. The F328Be is in entirely different class than any other speaker we have tested. The difference comes in impressive bass performance that is essentially distortion-free. This brings a level of clarity and dynamics that is addictive. You can play as loud as you possibly want and the speaker comes along happily. No sign of any change in speaker response. It is just at home playing audiophile tracks and rock and roll.
Needless to say, I am happy to recommend the Revel F328Be. If you want to buy a set of speakers and be done with it, you know what to get now!
This was our 100th speaker review and measurements!!! Hooray!
Hard to imagine testing so many speakers since January. When I bought the Klippel NFS measurement system, I was wondering how it would ever pay for itself. I figured if I tested 100 speakers, it would still cost $1000 per so we could have just asked a service to do the work. But here we are in less than a year and we are already passing that benchmark. Here is to another 100 speaker reviews!
Hi Amir,
are your Klippel NFS on-axis/off-axis and spinorama SPL curves referenced to 1 m or 2 m anechoic distance?
Revel F328Be one man install. :D
My F328Be arrived on a Truck in large flight cases.
1. I took off the top of flight case cover, put a towel on the ground and lifted the case on its side on top of towel.
2. From there I slowly scooted the F328Be cardboard box out of flight case.
3. I put the large cardboard box on two four wheel dollies and pushed it inside house.
4. Moved cardboard case to align with basement stairs and pulled it toward me ( I was in front of it on lower staircase)
5. Gravity brought it slowly down stairs with me pushing it back to go one step at a time.
6. Once in Basement placed cardboard box on end and scooted the speakers out.
7. Pull off the styrofoam protection and plastic covering and slid it across the carpet in place.
8. Rinse and repeat for 2nd speaker.
Moving them upstairs against gravity - would definitely be a two man job.
The Mensa candidates that delivered mine tried to set one speaker on the concrete floor of my garage, unwrapped from any protection, upside down. I yelled "STOP, YOU CAN'T DO THAT". They schlepped them up the carpeted stairs to my listening room, set them in place and put the ridiculous anvil cases in the attic. We moved a year or so later and the small moving company we hired did a great job moving them. I told them to take the anvil cases with them. They just take up too damn much room even on end or on top of each other.
This is pretty impressive! My salons and jl gothams took 3 and 4 people and I was not brave enough to take em in the basement so they stayed at the first floor in the family room. I would have liked those flight cases for my salons vs the regular cardboard boxes. Good job!
