Revel f 208 or Mofi 888
Kblade
I have a chance to buy revel f208 in walnut brand new for 3500.00 But also very interested in the mofi 888. Anybody recommend one over the other any recommendations appreciated. My room is 20ft wide and 35ft in depth with 9ft ceilings. Will be home theater and a music room. Room is slight left of neutral in sound, tube traps help to bring it back close to neutral. Will be switching back and forth from Dirac to no correction. I’m 60 years and like a neutral to slightly livelier sound. I have a pair of Revel M106 in my home theater in family room and love them.
Hi, welcome to ASR. :)
They're both very competent and well measuring speakers, but the fact you have a chance to get the Revel at that cheap price, I'd say grab those;
Aesthetically speaking, I also prefer the look of the Revels... to me they scream quality. The Mofi seem to have a more understated look, but only my opinion there.
JSmith
I don't know about the MoFi. I have F208, in a 19.5 ft x 34 ft x 10 ft room. Home theater with them being front R&L. I have M106 is secondary system. Results are quite excellent. So at least yes the F208 speakers can work very well in your situation.
Due to theater concerns where I placed mine the low end could be better. However I did use them strictly for music for a time and they are fine in a different location in that room. Since going to 5.1 I added Rhythmik subs and everything works very well. Of course depending up screen size and exact positioning you may very well have no low end issue.
JSmith
What if I could get the mofi for 2750.00 brand new which I should have mentioned. Also thanks for the welcome
In the end as always it depends on personal preferences and room/setup since both a well engineered loudspeakers, personally I would prefer the Mofi as it is coaxial (no vertical radiation problems), has a deeper bass and more continuous overall directivity:
Above plot generated by https://www.spinorama.org/
Personally I'd still go for the Revel, as to me aesthetics are important for speakers. If you the look of the Mofi's is pleasing to you, then save some money and go for those.
JSmith
Is the mofi more laid back than the the 208. I want a little more lively sound
The F208 has a bit more "bite" around 3 kHz which can be tiring though in some rooms or recordings, otherwise they aren't very far away. Both can be also equalised well to taste.
Get them , try them out, for that price you will have bucks left for couple of subwoofers, you will be set. But if you don’t like em you can get rid of them for no loss.
Thanks for the reply. I have 2 SVS SB Pro 4000 subs for theater. And when listening to music will switch to two Rel S510’s
For a large room, like your 6 meter one, I would go for the one with better high SPL handling. In this case it would be the Revels.
Considering the price of F228be and availability of F208, I think F208 is fine deal just like the 2750 Mofi.
Mofi has lower woofer XO point and coaxial driver, making it suitable for smaller rooms. Revels have vertical directives errors, since they are typical loudspeaker with TMW design, but the distortions at 96dBSPL/1m seems a bit better to my eyes.
But my little concerns on Revels, is that they are having quality control issues with their tweeter drivers in S.Korea recently. It is small market with limited consumers so I won't say it applies globally.
My Salon2 had one tweeter with HD problem. Ordered a pair, but both replacement had 2nd HD peak and I'm waiting for another pair.
One of my F228be tweeter had abnormal HD. Changed the driver, had the same problem, so I had to change the driver and the passive XO filter.
A member of the Korean community had a tweeter driver with 1.5dB less output. The dealer offered an driver exchange, but the replacement had excessive HD and is currently waiting for new one.
And Revel is not cooperative with their after service. Had to email and make phone calls several times with the dealer 'cause of such high failure rate in Korea, Revel was suspicious whether consumers were lying for extra drivers...
So do I recommend the Revel or not?
I recommend it. But just be ready and know you're not the only one, if you face such problems...
Those both are very good speakers. Hard decision.
If they were to be used when I am always seated in my listening chair with my ears on axis with the tweeter, I probably would lean toward the F208. If I were using them somewhere where I am not always going to be seated in my listening chair when listening, I probably would lean toward the 888 due to its better vertical dispersion (concentric driver).
Wow that sucks. I hope you get it worked out. Now I don’t know what to do. I’m to old to f with those problems. But I agree with spl output. Does this have anything to do with later produced 208’s
Confirmed cases are all recently produced beryllium drivers.
Revel sells in Korea is mostly turn-key offerings included in installations, so measurment from users are very scarce.
My major concern is not the QC itself, but the afterservice of Revel...
Some dealers exchanges the speaker first and handle the problems by themselves, in those cases attitude of Revel would be no problem, I recommend checking that part first.
Wow thanks so much. I’m going for the 888
For a room that size I would go with the Revel F328Be. Its tweeter height is an awesome feature when paired with a 20' x 35' room. Much nicer and more power full than 888.
IMO, at the price of Fx28be there would be so much more options...
The MSRP increase is so steep for a thin sheet of 1" beryllium, which makes no sense to me.
(And they recently did 60% discount here, which makes my opinion more concrete...)
And twice the $$ for one more 8" anodized aluminum woofer and minor upgrades? That's a big no...
BTW I'm not just a random hater or something, I bought two pairs of 228 with about 20% discount from MSRP, but against 208 these are still bloody expensive.
Yes, based on some users' helpful feedback (including @amper42), I went ahead and purchased a pair of F228Be and C426Be for my theater space. The F228Be arrived a few days ago, and they have exceeded my expectations. I'll post some more thoughts on the F228Be thread after I get the system dialed in further, but at the sale price I bought them for ($6000/pair), it really feels like a steal.
The F226Be is currently available for as low as $4000/pair from some retailers (in silver), so just a bit more than the F208. It shares the same tweeter and midrange as the F228Be, but has less bass extension since it's smaller. I'm not sure if the reduced bass extension would be an issue, especially since you already run subs. I think long term, the F226Be's may be able to keep up with your system more than the larger F208s. You can always add more bass refinement with subs, but you can't really improve the midrange/treble.
I haven't heard the MoFi, but they look like a good choice too. They do have slightly narrower horizontal dispersion (around 10 degrees), which may or may not be impactful. I find the wide dispersion of the F228Be makes it sound great now matter where you're seated, or if you're way back in the room outside of the seating area. The sound quality and dynamics really draws attention to itself. The higher tweeter position also makes it easy to maintain line of sight in my room if you're moving around.
Both speakers offer excellent measured performance. There will still be audible differences- if possible do try to listen to both speakers before buying is my suggestion.
I heard the MoFi speakers at the Ascot show at the weekend; they sounded tonally neutral and even handed as one would expect from the measurements, rather than “lively”.
The finish was perfectly fine and workmanlike but nothing exceptional, in my view.
Do listen to your heart as well as your head. If your aesthetic preference for the Revels is strong, and you plan on keeping the speakers for a long time, if you bought the MoFi speakers would you regret not getting the Revels?
