MarkWinston
- Joined
- Jul 13, 2021
- Messages
- 736
- Likes
- 578
Typical Revel, not so great on axis but near perfect EIR.
Thx! I'm dumb about doing exquisite measurements for room... Can I trust the measurement graph and auto eq settings from the receiver's build-in function and its accompanied measurement mic?You need to measure your room to answer these questions. Your room has modes that cause certain frequencies to get amplified and others attenuated. And of course the mixture of sub and this speaker is an unknown.
The comment on attenuation was hypothetical by the way. I would use it as is and see where you land once room/wall impact plays its role.
I disagree here. The most important measurement for center channel performance is probably wide and even directivity, and these fail that metric horribly. Horizontal directivity is super narrow, and totally inconsistent across the spectrum. For pure on axis listening, it may sound kinda good, but even then, I'd likely prefer M16 with a phantom center. The only real thing centers do for me is anchoring the center image to improve off axis listening, and these fail at that.Let's remember that the measurements are superb above bass frequencies.
Seeing all these Center speakers with laserbeam dispersion in a large part of their intended range, one has to wonder if that is because it measures better when played together with L and R speakers in a room or if it's just a case of companies ripping their customers off by selling turds?
Both look god awful to me . The Revel does look less terrible, for what it's worth.For a center speaker, yes:
That is laser focused beam. The Revel is much better in this regard:
Just a few thoughts..I disagree here. The most important measurement for center channel performance is probably wide and even directivity, and these fail that metric horribly. Horizontal directivity is super narrow, and totally inconsistent across the spectrum. For pure on axis listening, it may sound kinda good, but even then, I'd likely prefer M16 with a phantom center. The only real thing centers do for me is anchoring the center image to improve off axis listening, and these fail at that.
Also, the bass performance is terrible, to the point where it's going to be hard to get a good subwoofer integration without losing 5dB of efficiency.
The performance isn't surprising, given the limitations of the design. I actually think the Revel engineers did a pretty job here(maybe the best MTM center we've seen?), but I think the marketers had more say in this design than the engineers did. Pretty much what I expected. A very good try at making a very poor center design work . If aesthetics are less important, the Infinity RC263 is a much better speaker, at least going by the measurements.
What is surprising is the super positive subjective impressions, similar to the JBL 4309. Not saying they're wrong, and I do very much appreciate them. Reviews like this where the objective and subjective sides differ are the most interesting.
You can't fit the RC263 in the same space. These are completely different products/applications.A very good try at making a very poor center design work . If aesthetics are less important, the Infinity RC263 is a much better speaker, at least going by the measurements.
They are very different as I reported in my subjective listening tests. The Revel is far superior in this regard.Both look god awful to me . The Revel does look less terrible, for what it's worth.
IMHO, it probably reflects that most people on this forum do not have a proper home theatre/movie system and are mostly concerned with stereo (or if they do have a HT setup, it is connected to their small TV and/or it is not from this decade), so they have no clue what a proper center should be like Only plausible explanation really. Amirm showed a nice center in a previous post. Extension at -3dB down to 50Hz is a minimum in my experience.. A good example: Paradigm Persona C and Adam Audio Tensor Center. I have both and cannot quite decide which one I prefer. But they are both pretty much full range speakers and weighing close to 100lbs due to the heavy duty bass woofers and cabinets.What is surprising is the super positive subjective impressions...
I thought this speaker was not an MTM, but has 2 woofers, 2 midranges and a tweeter?I think it's just a case of management/marketing forcing engineers to produce an MTM design with a super tiny height dimension. The fact that even Revel engineers fail to get a good design tells me just how hard it is.
IMHO, it probably reflects that most people on this forum do not have a proper home theatre/movie system and are mostly concerned with stereo (or if they do have a HT setup, it is connected to their small TV and/or it is not from this decade), so they have no clue what a proper center should be like Only plausible explanation really. Amirm showed a nice center in a previous post. Extension at -3dB down to 50Hz is a minimum in my experience.. A good example: Paradigm Persona C and Adam Audio Tensor Center. I have both and cannot quite decide which one I prefer. But they are both pretty much full range speakers and weighting close to 100lbs.
Or they have a proper theater... and have another room with a flat panel display and no room for a proper center in that room... Or a vacation home where they need something in a tight space where proper center speakers are not an option... Here is what happened I bet...IMHO, it probably reflects that most people on this forum do not have a proper home theatre/movie system and are mostly concerned with stereo (or if they do have a HT setup, it is connected to their small TV and/or it is not from this decade), so they have no clue what a proper center should be like Only plausible explanation really. Amirm showed a nice center in a previous post.
Even Lyngdorf, who used to have only "life style" speakers IMO, now introduced this:I have to agree. Anyone expecting center speaker dispersion that is great beyond a certain point, will be effectively sitting right in front of either the left or right mains speakers. And will be quite off axis of the video image also.
ALL home cinemas are compromises in many ways. Even in a real theatre, the center has purposely limited dispersion, but we are sitting usually a minimum of 20-30 feet from the screen, so it becomes a non issue (for the most part)
No problems with that, I agree about the compromises and the reasoning behind it (but the C10 is still not useful anywhere with those specs, really, better off without it - if it could do 80Hz properly then it would be a different story and that is possible even with a slim design. Maybe;-)Or they have a proper theater... and have another room with a flat panel display and no room for a proper center in that room... Or a vacation home where they need something in a tight space where proper center speakers are not an option... Here is what happened I bet...
Marketing: We need a small, wall mounted speaker system for flat panels. Provides ridiculously small dimensions and said let us know what you come up with
Engineering team-List the problems they will encounter in making it sound good
Marketing: “Do the best you can”
And this is what they came up with within the constraints given. Actually pretty good given the constraints.
If you don’t have these constraints, many many better options. But if you do, it is nice that something can potentially sound pretty good. Just can’t overcome physics evidently with the mtm/mmtmm design, weather it be a 2way or 2.5way design.
