- Joined
- Jun 19, 2018
- Messages
- 6,652
- Likes
- 9,514
Excellent - thanks.Totally fine![]()
Excellent - thanks.
My thought as well. The Revel’s do come with Port plugs So you could always try it both ways.Another thought in fact. You could consider sealing the port. Not necessary, but may allow for easier sub integration.
M105 for that matter. A little smaller, a little cheaper, and just as good.Not sure about your room or center location, but an M106 makes a great center. May not work in many setups, it if you have a projection screen, they go nicely below the screen.
You can plug the port with a provided plug with no change to the bass above your crossover point and even less distortion. I know of a much cheaper than list option; asked them if they’ll ship to the UK. If so, I’ll hook you up.Yea I was thinking that too. I'd definitely try both ways.
That's very kind of you, thanks!You can plug the port with a provided plug with no change to the bass above your crossover point and even less distortion. I know of a much cheaper than list option; asked them if they’ll ship to the UK. If so, I’ll hook you up.
That’s a very good price, higher than my source but then with shipping about the same. If you want a pair then it’s an excellent deal.That's very kind of you, thanks!
I've found a new pair of M105s in the UK for £800 / $1030, not sure how that compares.
On a somewhat OT, but related note, my side surrounds turned up today. They're gorgeous! Can't wait to get them set up (2wks away though, unfortunately).
I have 4 of these for surrounds and rear surrounds. I really like them. Good mounting hardware, nice shallow cabinet, 90db sensitivity, and sound great.Those are on my list for side and rear surround, and they do look great. I’m also thinking of in-wall, but not many reviews on those.
I thought that too! Best wall bracket I've had for a wall mount speaker.Good mounting hardware
I'll likely do the same. I've got JBL Arena 120s as surround backs at the mo. Wall mounted, which I know Toole has said (for the 120s specially) isn't ideal, but they'll do for now.
I have these arriving tomorrow. I won’t be able to mount them right away but I can share first impressions.Could you point me towards the wall bracket in question? I've been struggling to find an acceptable way to mount m105's as rear surrounds.
https://www.amazon.com/Mount-Universal-Clamping-Bookshelf-Mounting/dp/B01MZE0O8U
First impression on the brackets: compact, elegant, sturdy, very good horizontal toe-in adjustment, only 7.5 degrees vertical, so keep that in mind. The cover is a little cheesy but most brackets don't even have a cover. The price is outstanding. The only question I have is the ability to screw into the bottom of the Revels to hold them in place sufficiently. I won't have mine in hand for three weeks to confirm, I'm afraid.Thanks, that would be appreciated. Wall mounting is my only option, other than placing a speaker on a piano...
I almost ordered those when I was considering M105’s for surrounds. What speakers are you going to use them with?First impression on the brackets: compact, elegant, sturdy, very good horizontal toe-in adjustment, only 7.5 degrees vertical, so keep that in mind. The cover is a little cheesy but most brackets don't even have a cover. The price is outstanding. The only question I have is the ability to screw into the bottom of the Revels to hold them in place sufficiently. I won't have mine in hand for three weeks to confirm, I'm afraid.
M105s - three sets. Have you found any brackets you like better?I almost ordered those when I was considering M105’s for surrounds. What speakers are you going to use them with?
