- Joined
- Dec 12, 2019
- Messages
- 15,965
- Likes
- 36,083
I suspect (???) that some JBL fans might not share that opinionNice to see NFS measurements of a large speaker, that match well with previous measurements!
And yes, Revel line of Harman is top!
Not to mention temperature and relative humidity...Wonderful!
But I am still very worried that you might be positioned some slight offset relative the sea level?? (Just kidding!)
Earth's magnetic fields probably don't align with the true north in that location either.Not to mention temperature and relative humidity...
Thanks for this. Viewing on a phone at the moment. So am I seeing this right, the slightly more squiggly line is the Klippel?
This is a review and detailed measurements of...
So, are we saying, that because of the additional midrange driver, vertical lobing would be negated when these are positioned in an upright (I guess this is upright for a center speaker) position, and thus, could be used as L-R speakers as well?
This is not an easy design to pull off, but this is a premium product made by people who know what they're doing. I think you will find that other CC speakers fare far worse.
Hmm..
Wouldn't in that case current vertical reflections become horizontal, and those are not so stellar.
Yeah, what's so impressive about this speaker is that it essentially has the radiation pattern of a good vertically aligned speaker despite being a long center. This is rare; most center speakers have good vertical directivity and poor horizontal drectivity instead. As we know, the latter is more important, but center speakers usually make that sacrifice in order to be able to fit under a TV, since they're used in conjunction with stereo speakers anyway. The revel doesn't appear to be making any major sacrifices thanks to clever engineering.
A pair of transmission line subs from Wisdom.Wow, these measure very well. What sub do you use with these?
It is just what the midrange aligned vertically with the tweeter does. Another trick effect is increased horizontal directivity of double woofers - totalling extremely well behaved hor. dispersion! It is so sad that most C speakers are two-ways.
Similar 3-way centers also available from B&W, Focal, NHT, Bryston, Paradigm etc.
The "normal" Klippel used for measuring transducers can also measure the impulse response and diaphragm excursions, which I think it's only necessary for engineering purposes.
Not sure if this can also be done with NFS, but it will be great if we can also see the impulse response of woofers and midranges.
Transducers mounted on one enclosure and separating each linked speaker to one binding post will be an issue though.
