Paul7777x
- Joined
- Feb 11, 2026
- Messages
- 646
- Likes
- 914
I really don’t see anywhere that a Beryllium tweeter is inherently harsh, sharp or anything of the kind.
Nor have the Revels anything but the finest rep and measurements.
So if you’re hearing anything like that it’s not your speakers.
As ever, any issues are almost certainly room and speaker positioning problems.
As mentioned above, the room is at least a bit hard and bare. The floor, and coffe table provide acres of reflective space.
And, also as above, you may well be making and HF worse by having the speakers out from the wall. It may be causing a bass or mid/bass cancellation that forces the sound to appear toppy.
Personally I’d get at least a good sized rug. As thick as is reasonably possible. And get rid of the coffee table (if that’s genuinely impossible, then replace it with one that has less surface area).
I’d also hardly continue without introducing some DSP room correction.
