FiftyTifty
- Joined
- Aug 9, 2023
- Messages
- 38
- Likes
- 7
Hi! I'm FiftyTifty, and you might remember me from complaining about power draw causing noise on my speakers.
Yeah it's back and I'm at my wits end with it. After getting the Behringer Hum Destroyer and using my Creative soundcard, it was tolerable but was slowly getting more and more on my nerves. Took my PC apart, cleaned everything, and this time made sure to add all the standoffs to the case and screw the motherboard to them. Since those standoffs are used to ground the motherboard's components.
Yeah well, turns out the sound card doesn't fit in unless I take off the shield, which gets super crazy interference just like the crap Realtek integrated one.
How bad is it? Absolutely awful. It's like hearing an unending dial-up tone even when the PC is idle. Here is a video with the audio cables plugged into the speakers:
And when the audio cables are out...It still happens. Not as loud and it's high pitched, but the exact same behaviour: When PC is idle, less noise. When PC is doing what I bought it for (gaming, Gaea, modding) it gets louder and more noisy. Unfortunately my phone couldn't pick up the high frequencies when I recorded it, so no point sharing the video.
What have I tested and spent lots of (I'm poor) money on? Well:
Optical -> Unbalanced DAC -> RCA -> RCA Speakers
Optical -> Unbalanced DAC -> RCA -> XLR Speakers
Optical -> Audio Interface (Roland Duo Capture Ex) -> 6.35mm TRS Speakers
Optical-> Balanced DAC -> XLR -> 6.35mm Speakers
Optical -> Balanced DAC -> XLR -> 6.35mm TRS Speakers
Optical -> Balanced DAC -> XLR -> 6.35mm TRS Hum Destroyer -> 6.35mm TRS Speakers
Did the above tests with USB connections instead of optical to the DAC or audio interface, same behaviour.
For DACs? I've tried the Schiit Modi 2 uber, some SMSL unbalanced thing, and a more expensive SMSL balanced DAC. All of them had this behaviour. USB -> DAC connection were even worse, with the noise being twice as loud, including on the Roland. Even when all the devices are on the same power strip (PC, DAC, audio interface, computer screen, speakers) and everything else powered off (yes, even the wifi router)? Nothing changed.
At this point, I'm going to get an engineer in to check out the wiring of the office and see if there's anything that can be done. In the meantime...I guess I can try different optical cables? What's a good brand that I can get in the UK? Lots of Chinese resellers on Amazon and Ebay, but actually can't find any brand recommendations off of Google.
