Hello, i need some help with choosing new passive bookshelf speakers.
I currently own a pair of Wharfedale Diamond 220 and they are quite good and all, but i have this specific problem. I listen in room with low reverberation and can hear some kind of resonance which is gradually decaying somewhere inside of the speakers.
Here it is, about 320 hz:
So i decided to get myself a new pair of speakers. I have a subwoofer, so i don't need speakers to play low bass.
My current picks are either Dali Spektor 2 or Wharfedale 12.1, but i will gladly check any other recommendations.
I only found some frequency response here and there, but nothing regarding resonances.
I thought of listening to them at local speakers dealer shop, but then i decided to check my speakers in other rooms at home first.
I tested them in 2 rooms with default room reverberations, here are results:
In other rooms i could not distinguish between room reverberations and speaker resonance, so i decided that listening trip to local shop is not worth it.
About new speakers. I don't necessarily need super flat frequency response, since i can simply use equalizer, but as far as i understand, they need reasonably good directivity to equalize well.
So, if anyone know something regarding my problem, or can say anything about or even measure Dali or Wharfedale speakers, would be great to know anything.
Other than that, recommend me some, preferably resonance free, budget speakers. My budget is 500$ for pair, but maybe i'm willing to spend some more...
