That's slightly true, but a bit simplified.This plays the test signal used on this forum to measure phono cartridges.
As a reminder for those unaware, every turntable constantly adds a high-amplitude signal to the music, up to 20 Hz.
All the time.
Big problem.
High-amplitude resonance up to 20 Hz always occurs; it's unavoidable.If you miss-match the compliance and mass, 1) the resonance is at warp frequencies meaning the playback is unstable on real-world disks OR 2) the resonance is in the audio band.
With a different effective mass you principally change the frequency of the resonance, assuming cartridge compliance is unchanged.If we significantly increase the effective mass, we reduce the amplitude of this resonance,
Reducing the peak s possible.High-amplitude resonance up to 20 Hz always occurs; it's unavoidable.
What matters is how high this amplitude is, and it's usually very high.
If we significantly increase the effective mass, we reduce the amplitude of this resonance, but this will place greater strain on the stylus cantilever suspension and, consequently, accelerate the degradation of its technical parameters.
Vinyl records and turntables are an outdated technology for recording and reading sound; they should be available only in museums.![]()
-20 dB, good result
Effective mass and cartridge compliance both have a large impact on the frequency of the resonance, and the amplitude.-20 dB, good result
Of course, you can reduce this amplitude. The entire history of turntable development is a constant battle against this undesirable phenomenon. A losing battle.
The problem with the average vinyl enthusiast is that they almost never measure this amplitude level for their system.
They measure the cartridge, not the level of unwanted resonance. It's ridiculous.
Some vinyl enthusiasts calculate effective mass, compliance, etc., as if it had any significant impact on this amplitude level. Changing the effective mass by a few grams won't change much.![]()
Well, you are on ASR, and we all know this. We strive for good technical setups and what matters. You could buy the laser turntable if you want to or use clever damping, like the Shure cartridges did. And horizontal damping for the arm. Flat LPs helps. As a last step one can add subsonic and elliptical filters in the RIAA to save headroom in amps and speakers. The measurement I showed is without such filters, and you save up to 20 dB more with those.-20 dB, good result
Yes, it was quite possible to reduce the peaks earlier than 1977 (APT/Holman PreAmp):
Use any of the several test LPs with resonance bands. The resonant frequency can be observed visually, by watching the cartridge moving, up and down, or side to side depending on the modulation. No need for test equipment. Ideally, this unavoidable resonance should be at around 11Hz, above warp frequencies and below lowest audio frequencies. If too high, mass can be added to the headshell, if too low, more difficult to fix, but a lighter headshell if removable can help, otherwise a change of cartridge to one less compliant may help.Please describe how the average vinyl enthusiast should measure the level of unwanted resonance in their turntable system up to 20 Hz.
What level can they consider good, and what level is bad and needs improvement?
What should they do if the level is too high?
Please remember that the average vinyl enthusiast is not an ASR forum user; their technical knowledge is much lower, so they expect simple, understandable advice.![]()
I do not know, I have been analog since the mid 70's (when I started this journey, there were Audio/Video clubs. I started working at Radio stations were it was really important that the cartridge did not jump out of the groove).Please describe how the average vinyl enthusiast should measure the level of unwanted resonance in their turntable system up to 20 Hz.
My advice would be not to bother to measure it.Please describe how the average vinyl enthusiast should measure the level of unwanted resonance in their turntable system up to 20 Hz.
