Repurposing an outdated Xeon workstation into a quiet, high efficiency, high speed (10Gbps) TrueNAS server
Hello @rcstevensonaz,
Thank you for the website link and your kind suggestions. I will definitely take them into serious consideration when purchasing a new 8TB HDD for my TrueNAS server.
I sincerely hope that the current, insanely high prices for 8TB SSDs and 8TB HDDs will come down during the upcoming Black Friday period and beyond. However, according to online articles on market trends for SSDs and HDDs, the pace of price declines is expected to be very slow over the next one to two years. Therefore, I’m really torn about when I should buy 8TB SSDs and 8TB HDDs. Will that timing come within the next six months, or will it take more than two years…?
In any case, until then, I plan to continue effectively using my current evaluation platform: a 10.63 TiB ZFS RAIDZ2 pool consisting of a 6+6+4+4+4 TB mixed HDD configuration, of course together with the complete backup platform (ref. my post #42).
Since TrueNAS OS strongly recommends keeping the utilization of a RAIDZ2 storage pool at 80% or below, I will manage my system accordingly to ensure my used capacity remains at 8.5 TiB or less.
Since I am already using 7.65 TiB, that leaves only about 1 TiB of additional storage capacity available. However, as I shared in my post #1, the space required to store full VHDx copy images of the Windows OS SSD drives from about 10 PCs in my home and SOHO environment every two months is enormous.
Once I have built a RAIDZ2 SMB storage system with approximately 21TiB using five 8TB HDDs, I plan to store the bimonthly VHDx images for all PCs enabling me to go back one year. Fortunately, even with my current 10.63TiB of SMB storage, there is sufficient capacity to store the past six months’ worth of data.
Therefore, as long as I delete VHDx images older than six months as needed, there will be no issues with my current operations, including the storage of other large data files (such as numerous raw/jpg/tiff photos, videos, audio track files/libraries, emails, office documents, my ASR thread copies, and so on), there will be no disruption to our operations for the foreseeable future, I mean for the coming a few years.
Driven by my curiosity and interest in this "efficient Xeon TrueNAS with 10GbE LAN" project, I want to install one 8TB M.2 NVMe SSD and five, plus two (2) as spare, 8TB HDDs as soon as possible (ref. my posts #43 and #50), but I am telling myself that I should exercise restraint for now.
__
Prices are high for sure. For reference, my average 4TB WD Red Pro cost was $115 per drive (2019) and the 8TB WD Red Plus was $169 (2024). Like you, I will not be adding additional disks for while.
Keep in mind you only need to add 3 drives* (replacing just the 4 TBs) to gain ~6 TB capacity (3 data drives x extra 2 TB per data drive). Then later you get the remaining capacity jump when the two 6 TBs are replaced.
* Also, I'm sure you have it covered, but keep in mind you really need to have at least 1 spare drive (of you smallest capacity size in the pool) on hand for replacement. That drive should have been fully tested (burn in ) before setting aside as a spare. So in reality, that means you need 3 x 8 TB drives plus at least 1 (or ideally 2) drives that are at least 6 TB.
Yes, agree with you, that is a nice compromise in the "way forward" in my present Xeon TrueNAS ZFS RAIDZ2 project.
If I would firstly by three (3) 8TB server HDDs to rebuild my RAIDZ2 in 6+6+8+8+8TB configuration, the pool size will be 18TB (16.37TiB) enabling ca.15.5TiB SMB storage; I need to have at least one spare 6TB HDD which actually I have now. (The detached three 4TB HDDs can be used in the off-line complete backup PC.)
Then, when I would add two (2) more 8TB HDDs later on, the final RAIDZ2 configuration will be 8+8+8+8+8TB enabling 24TB (21.83TiB) giving ca.21.0TiB SMB share. :)
At that time, I need to have at least one 8TB HDD as spare. The detached two 6TB HDDs again can be used in the off-line complete backup PC.
Consequently, the simple independent HDD configuration in the off-line complete backup PC (I already use four HDDs including one 6TB HDD) will be 6+6+6+4+4=26TB (23.65TiB) which is much more than enough for the complete backup of TrueNAS RAIDZ2 SMB share, 80% upper limit of 21.0TiB, i.e. 16.8TiB.:D
Personally, I would strongly advise against RAIDZ2 (or other) for a backup set that is offline. IMHO, far too much risk of corruption to your backup set from the RAIDZ mechanism failures at a time when that might be your only hope for retrieval — you don't want to risk multiple disks needing to be resilvered (or even corrupted from hard failure) when you go and fire up the backup. That is even if all disks are eventually recovered without a catastrophic RAID pool failure.
But again, I'm a huge mirror fan for its resiliency and simplicity. For your backup set, you can even use multiple mirror vdevs (e.g. 6+6 & 4+4 & 4+4 = 14 TB). And each vdev can be resilvered / repaired separate from the other — potentially up to 3 failures concurrently in best worst case. And also keep in mind that some of the data on your existing RAIDZ2 is emphemeral and kept there on the hot pool for convenience; but does not really need to be backed up further.
No worry, please.
In my complete backup platform with outdated ASUS B75-M Plus M/B and Windows 11 Pro OS plus 10GbE NIC, I do not use any RADID configuration, but all the HDDs are just simple NTFS formatted drives/partitions; they are independent simple volume HDDs (please refer to my post #42). :)
In the worst case, all of the data stored in TrueNAS Sever can be "recollected" from the 10 (ten) PCs, all of them have OS SSD and several HDDs in manual mirroring manner, in my home and SOHO...
No worry, please.
Down the road, you might want to explore the power of (a) ZFS snapshots and (b) ZFS send/receive as part of your backup archival processes.
Thank you; yes, I know and understand well about your point.
At present I prefer, however, to perform my weekly backup procedures to be done "from client backup Windows PC" via established 10GbE LAN using batch commands of reliable "FastCopy (64bit) ver.5.12.0".
OK, I'll bite. How much faster is your backup using 10GbE vs. a 1Gbps adapter from the Windows PC?
Since I have already installed 10GbE NICs in TrueNAS Server and client backup PC with silent 10GbE LAN (Cat6A cables and silent 10GbE switching hubs), I have never tested backup via 1GbE LAN.
You can find in my post #1 that the CrystalDiskMark 9.0.3 x64 in 4GiB setting showed ca. 660 - 800 MB/s sequential write/read, near max. by NICs on PCIe Gen3 slots, reflecting the RAM cache in the TRueNAS Server; for large file download from the TrueNAS, it depends on the local single HDD's "write speed" in backup PC, usually around 120 MB/s.
In any way, my weekly complete differential backup can be finished within 2 hours. :)
