Repurposing an outdated Xeon workstation into a quiet, high efficiency, high speed (10Gbps) TrueNAS server
Hello everyone! Thank you for your kind attention and nice comments on this new thread.
Sorry, but since I am tightly trapped by several Zoom remote meetings today and tomorrow (relating to the tragic earthquake happened recently in Kyusyu Island), I just very briefly and "generally" respond to all of your kind comments and curiosities.
By "high efficiency" in the thread title, I mean not "electricity consumption efficiency" but I do mean "I/O throughput efficiency" in comparison with local outdated SATA 6G SSDs/HDDs.
Furthermore, the average apparent power consumption of the present TrueNAS server is ca. 110 Watt (1.1A in AC 100 V here), and I will not operate the NAS server non-stop 365 days; it is highly possible that I will turn-on the TrueNAS sever only for about 5 hours in a week for various small and large files transfer into the SMB storage; the newly built 10GbE LAN, on the on the hand, will be always alive for client-to-client high-speed data transfer.
Next, the default setting of the CrystalDiskMark 9.0.3 x64 is as follows in below Fig.08;
View attachment 548542This means that CrystalDiskMark 9.0.3 in Default setting measures the typical "total I/O throughput", not the pure RAIDZ2 HDD I/O speeds, but does measure the "total" of possible distributed (12-core 24-thread) Xeon processing using 64 GB RAM working partly as "cache", 10GbE LAN throughput, plus some other unknown (to me) caching in ZFS RAIDZ2 storage configuration spreading over five (5) HDDs, even though I have not yet installed high-speed M.2 NVMe SSD for ZFS RAIDZ2 caching.
Also please note that all the client PC and TrueNAS server hardware configurations are running on PCIe Gen3 or Gen2 platform (not Gen4 or higher).
It is electrically efficient if you take what it's though-put is and the power it use's in 5 hours but say it did X amount and used X amount of power in 24 hours instead 5 hours.
Speed and power cost money, how fast do you want to go?
But, if your throughput is very fast and you find that you are NOT operating 19 hours a day because of you high power consumption and high through-put, then your power use in 5 hours is off-set by your ZERO (or maybe some just idling use) over the next 19 hours, averaged into your daily use.
Hello @EJ3,
Thank you for your kind attention on this Xeon TrueNAS project thread. I appreciate and understand well your points.
You would please refer and understand my posts #43 Part-08 “The Way Forward” with present “Xeon 10GbE TrueNAS Server Project” as well as #50; I usually power-on the TrueNAS server only about eight (8) hours per week.:)
As I wrote in my post #13, the average apparent power consumption of the present TrueNAS server is ca. 110 Watt (1.1A in AC 100 V here in Japan).
Reactions: EJ3
These Xeons are workhorses. 12 cores, 40 lanes, 4 memory channels. That is level up from desktop hardware. But at 22nm, 130w TDP and limited powersaving capabilities it's not efficient with power by todays standards.
Doing things in parallel is the key, that's what it is designed for. I/O purposes with disks and network/PCIe are done effortless by these chips. To keep it cool, quiet and low on power a simple trick is to lower the max. CPU frequency. This automatically disables turbo. Questionable how low it can go, 2.7Ghz is the base frequency. Fixed at 50% it should stay there and not move up.
(ECC) RAM also consumes a bit of power. While it's good in general to have more, gross oversizing yields nothing but power consumption. But I would look to do 4 channels with this CPU, so 4 modules in place. Channels have a much bigger impact on overall performance than RAM frequency. If available ECC is def. to be preferred.
Can't send it to Japan, but I have drawer full of old DDR3 ECC. Others probably too. :)
Hello @Ruediger,
Thank you for your kind attention on this thread. I essentially agree with your points.
As for RAM, I currently use eight (8) non-ECC 8GB module on all the eight (8) memory sockets of the repurposing XP9X79 WS M/B, i.e. total 64GB, which work quite nicely not only for TrueNAS OS operations but also as efficient cache for ZFS RAIDZ2 operation.
As I shared in my post #50, at present, I decided not to use ECC modules in the TrueNAS server; I essentially agree with the stance of the contents of the referenced web article, and @voodooless's discussion in post #43, as well as the contents of this nice web article entitled "How to Build a NAS With TrueNAS Scale: 10 Steps [2026]" written by Elias Virtanen, dated August 15, 2026 shared in my post #53.
_
In general it works without ECC. You decide how important the data is. For private use we usually can live with the occasional bit-error.
I agree 64gb is desirable with ZFS, so 8 x 8 it is. The ability to save power and temperature there is rather small compared to a Xeon. It's just when you have choices, 4 modules is optimal.
What I always recommend for projects like this is Dell FLIR dual 10gbe cards. They cost like $15 on ebay, an adapter to PCIe another $10 and you get flawless support from Win and Linux. With a board with a lot of slots the higher ranks of an Intel X5xx are not needed (save lanes, slot size).
Even for personal use, I would argue that ECC is worth the investment if you are taking the effort to create a ZFS storage system — one of whose primary benefits is prevention of bit rot.
My experience with ZFS is that 64 GB of RAM is massive overkill for a home-based systems. Avoid running de-duplication, and 16 GB (or even just 8 GB for pure store & serve of sequential files) is sufficient.
IME second-hand ECC systems with xeon are not more expensive than non-ECC, it just requires picking a professional workstation with ECC (e.g. FS Celsius 740, HP Z4x workstation). These machines are designed for almost silent 24/7, no need for a server HW.
Agree that the second-hand market for memory is the way to go — chips that have been stripped out of decommissioned enterprise systems.
But using ECC only requires support from the CPU and motherboard. For intel-based systems, that usually means you need Xeon-class CPU, though the Core i3 CPUs (at least used to) support ECC. The selection from AMD (at least in the past) was much wider with supported ECC on a broad range of their CPUs.
For example: I used to run ZFS quite well on an old AMD Athalon II X2 CPU (from 2011) with 8GB ECC ram. That system would still have sufficient power for a home media ZFS server.
Probably good advice on ECC if data integrity is indeed a top priority. I thought about my servers for a moment. ECC everywhere. Just AI has to do without.
My observation with ZFS is that people chose it for different reasons and often not too many combined. One top motivation seems to be doing softraid so to skip hardware controllers. Better softraid than just some lvm. And second copy-on-write, journaling. I think it's nice when set up correct for the need, but needs good hardware (and backup ofc). Any RAID to me means triple digit TBs, but the OP is not into too much storage. I think a bit more RAM should scale good, but really no idea how much he would really allocate.
You are correct that people choose it for different reasons. For me, the use of ZFS (and ECC) it is entirely about long-term storage with high resistance to silent bit rot in my media files. It is also about the simplicity that ZFS offers over the complexity of hardware-based RAID controllers (and the catastrophic risks if I screw it up).
But I would strongly challenge your notion that RAID is for large "triple digit TB" storage! Even a single TB of important data is worth protecting.
My case: I am running triple mirror (ZFS Mirror-3) for a just a few TBs of ripped CDs, photographs, and personal documents. That approach fully satisfies my goals of (a) protection from undetected bit-rot, (b) long-run resilience from failed hard drives taking out my dataset, and (c) extremely low chance of screwing up the drive replacement process.
Different schools with the same goal. Data protection. :)
I would challenge the complexity of RAID or HBA controllers. Last but not least with ZFS it's also a controller handling drives, just maybe a much simpler one from the pure onboard to raid-on-cpu class. Or maybe it's the same RAID in HBA mode, just because of ports, cache, performance.
With a hardware RAID controller (e.g., LSI card in IR mode), I have to manage disks and health primarily through the BIOS.
With ZFS, it is just a bunch of disks managed at the operating system level — whether simply using extra SATA ports on the motherboard, SATA ports on a PCIe SATA expansion card, or a JBOD HBA (e.g., LSI card in IT mode). All implementations of ZFS seem to advise against using disk drives that are controlled by a hardware RAID system.
Between the two, IMHO and experience, having ZFS just manage a set of disk drives at the software level (zpool, zfs) is far easier for someone who is not a computer technician.
Yes, with softraid of any kind we want simple yet reliable and fast drive ports. No RAID ROM. But many controllers serve well there with their HBA modes.
For smaller datasets (up to 8TB) personally I like enterprise SSD and rather frequent backups. Not imaging, differential schemes that allow me to go back for years if necessary.
Agreed. I've used exclusively LSI HBA cards flashed with their "IT firmware", which essentially removes all RAID functionality on the card itself. But that was when I needed to support 8+ hard drives. Now that I can fit everything on a single 3-way mirror, the on-bard SATA ports are also perfectly fine for what I need.
And given the cost differential, I'm currently partial to 8 TB WD Red Pro drives in 3-way mirror. That large of SSD was expensive, and has only gotten worse.
That said, I started originally with 512MB WD drives about a decade ago, and simply upgraded through 1TB, 2TB, 4TB (my current level), and then replacing with 8 TB now as drives fail. I keep looking at jumping to SSD, but WD Red Pro still seem the most economical for a home setup.
It's not so easy with storage in general atm. As an IT guy I have a lot lying around. Not long ago times were easy. A 8TB Micron which last dozens of PBW was under $1k.
I'm also holding on to many, many Exos18, 20 and 28. Just stopped selling because having to buy again is no fun.
But this is a cycle. RAM, storage.... they do that every few, or not so few, years. When people pay a lot of money, someone will ramp up production. And we move in the other direction again.:)
Hello, @Ruediger, @rcstevensonaz, @phofman,
Thank you for all of your discussions and information which are invaluable not only for me but also for many ASR members visiting/viewing this thread, I believe.
By the way, I continue testing and evaluating stability and robustness of my ZFS RAIDZ2 pool intentionally consists of five (5) HDDs, of course all CMR ones, in mixed brand, capacity (6+6+4+4+4TB) and rpm.
Today, I am testing (or a kind of stressing) again the RAIDZ2 storage pool by intentional "cold-swapping" and "resilvering" one of the 4TB HDDs. It looks the time needed for "resilvering" depends on the newly installed HDD, but I do not know what/which factor(s), such as physical cache size within the HDD and rpm etc., would be mainly contributing to the "resilvering" time difference; this time, it will be completed in about 8.2 hours instead of 13.6 hours last time (ref. my post #54) under the almost same storage condition of 72% = 7.65TiB used, available 2.98TiB, of 10.63TiB total usable capacity.
I will share the details, hopefully tomorrow, after completion of the ongoing "resilvering".
__
Again, resilvering one of the 4TB HDDs after cold swapping
This post is a follow-up of my posts #54 and #76.
In my post #54, I shared my intentional cold swapping and resilvering of one of the 4TB HDDs in the ZFS RAIDZ2 storage pool, i.e. WD40EFRX 5400rpm was replaced by ST4000DM00 (Seagate), and the "resilvering" of ST4000DM00 took 13.6 hours under the storage pool condition of 72% = 7.65TiB used, available 2.98TiB, of 10.63TiB total usable capacity.
The day before yesterday, TrusNAS OS reported/alerted that a few sectors in the ST4000DM00 were unreadable even though the total storage space and data therein were perfectly secured which reminded me of my less reliability on Seagate HDDs especially old models like ST4000DM00.
I decided, therefore, cold swapping the ST4000DM00 with empty (initialized) 4TB Hitachi_HDS724040ALE640 7200rpm, and then resilvering it in the present ZFS RAIDZ2 pool.
I do not know what/which factor(s), such as physical cache size within the HDD and rpm etc., would be mainly contributing to the "resilvering" time difference; this time, it took 8.2 hours instead of 13.6 hours last time (ref. my post #54) under the almost same storage condition of 72% = 7.65TiB used, available 2.98TiB, of 10.63TiB total usable capacity.
After the successful "resilvering", the ZFS RAIDZ2 storage pool is perfectly healthy in 6+6+4+4+4TB five (5) HDDs;
(1) WD60EFRX 5700rpm,
(2) WD60EFRX 5700rpm,
(3) Hitachi HDS724040ALE640 7200 rpm,
(4) WD40EFRX 5400rpm,
(5) Hitachi HDS724040ALE640 7200 rpm,
enabling 10.63TiB SMB share storage where 72% = 7.65TiB used, available 2.98TiB.
As I wrote in my post #56, Toshiba N300 Pro or N300 NAS Systems series CMR 8TB 7200rpm HDDs —3-year domestic warranty in Japan— will be also in my scope of selection for ZFS RAIDZ2 pool in the-near-future final construction of ZFS RAIDZ2 using five (5) of server-grade 8TB HDDs.
_
I've seen recent articles on long-term drive longevity that might be worth taking a look at. In those, WD and HGST both scored very highly while Toshiba was lowest.
Also for ZFS in a home setting, I believe 5400 drivers are preferable due to lower power draw, lower noise, and lower cost. Mixing and matching is not an issue for ZFS; just simply there is no reason to be adding 7200 spinners.
Thank you for your quick response really invaluable for my present Xeon TrueNAS project.
Would you please let me know the link to the web article on longevity of recent server HDDs?
Furthermore, which 8TB server HDD do you recommend at present for my present TrueNAS project?
I will be purchasing six or seven 8TB HDDs during or after Black Friday period when the price(s) will come down to my budget level...
Article: https://www.tomshardware.com/pc-com...rs-ranks-hgst-most-reliable-and-toshiba-least
Peer-reviewed study of 443,000 Backblaze hard drives ranks HGST most reliable and Toshiba the least — Analysis of 1.66 million drive-years finds Seagate and Toshiba HDDs fail at roughly twice the rate of WD and HGST​
Note that the article uses Seagate as the baseline (100%), and then presents the other drive percentages relative to that baseline.
As for recommendation -- there is Coke and Pepsi, and brand loyalty is a thing.
For myself, I have been extremely satisfied with the WD Red Pro 5400 RPM ("NASware 3.0") line over the past years, growing through 1TB, 2TB, 3TB and now 4TB increments. Currently, the vast majority of my current system iteration (~15 drives over various zpools) are WD40EFRX.
Based on recent WD product line changes, my new drives going forward have been 8TB WD Red Plus (NASware) at approx. 5640 RPM [WD80EFPX]. However, I only have one of those in an active ZFS pool; and that was based on my assessment of the best option back in 2024.
That said, I cannot offer much insight on RAIDZ2. I am 100% committed to the three-way mirror (ZFS M3) strategy and personally choose not to use RAIDZ2, despite having to purchase a few extra drives as a result. But ultimately, my data set sizes are relative small and not growing that fast.
Edit: do NOT order all of your drives as part of the same order — drives from the same batch series will have highly correlated failure timelines... so whether that is a shorter or longer timespan, they are more likely to fail around the same time as the others. If sticking with a single vendor model as I do, spread the orders over time and place the orders from different retailers. Or, intentionally choose a strategy of comparable model drives (e.g., similar RPMs and sizes) from different manufactures.
