Replacing MusicalFidelity w/WiiM + Coyote?
Jimothyreport
Hi all, after many many years my inherited MusicalFidelity A3.5 integrated amp has left this mortal coil and I’m trying to figure out a replacement.
I’m currently running:
-Pro-ject Debut Carbon Evo
-Microrendu w/SGC linear power supply
With:
-NAD PP2e phono preamp
-Schiit Modi iii DAC
Out to a pair of Dynaudio Emit M10s.
Overall, I’d say I listen 60/40 vinyl/streaming (via Qobuz) so trying to figure out what comes next. I rent an apartment in NYC so floor-standing speakers/room treatment beyond the carpet we have are not really feasible.
I’d been eying a WiiM Ultra into a Buckeye NCx500 but would be curious to hear if folks think I’d be taking a step back on the DAC/phono pre (guessing pretty unlikely on the latter?) and/or these choices would severely limit my options if I want to upgrade things like speakers in the future.
Have generally really enjoyed the current system and wouldn’t otherwise be on the market. Cheers!
P.S.- crazy how fast one can spend many hours on this site
With:
Welcome to ASR!
Using the Line input of a WiiM Ultra, you could compare the sound of the NAD phono preamp to the one in the Ultra. I don't think I would perceive a difference.
I think your suggested combination of a WiiM Ultra as a source for a Buckeye NCx500 amp will work well. Buckeye now sells cables to connect a WiiM Ultra to their amplifiers.
Thanks for the reply!
I had typed out a whole long reply with many follow ups, but I think I just needed to hear I wasn’t crazy and see how it sounds.
My father is a retired audiophile who was encouraging me to spend much more, and maybe one step at a time.
If I end up liking this setup, the next thing to upgrade would probably be the speakers? I had been looking at some integrated amps at 2x the combined cost of the WiiM and the Coyote from Naim/Focal/Marantz type companies, so hoping this gets me there with some room to grow with less money down?
Yes, loudspeakers 'may' be the next upgrade.
You may be satisfied with what you hear from your Dynaudio Emit 10 loudspeakers with the enabling of the 'RoomFit' room correction feature of the WiiM Ultra.
One step at a time can make sense regardless of the amount spent. :)
I run my WiiM Ultra into a DIY Hypex amp, so the amp is not disimilar to the Buckeye you are contemplating. The Buckeye would have a newer Hypex module, or a Purify module, depending on how much you want to spend. The sound I get is excellent. The WiiM far exceeded my expectations. In reality, it blew them away.
Prior to the WiiM I had an SBC running Volumio into a stand alone Emotiva DC-1 DAC (Stealth DAC) into the Hypex. The Emotiva DAC got a pretty good review here on ASR, but I find my current set up superior in a variety of ways.
The WiiM phono stage will meet or exceed your NAD unit and the WiiM DAC is superior to the Schiit. And you get it all in one unit and a lot more.
The WiiM is not expensive, but is a rediculous bargain. Get a decent amp and then spend your money on quality speakers that measure well on Klippel on ASR or Erin's page.
I also have a Project Debut Carbon Evo and WiiM Ultra. I've tried a range of DACs with the ultra and never could tell any difference to the Ultra's own internal DAC (when level matched). One problem I did have though is the Ultra's internal phone stage appears to be poorly shielded and would pick up electrical noise. I tried two separate units and the same problem was there with both. It might not be problem for you in your home, but happily I didn't have any such issues through the Ultra's line-in via an external phono stage, so keep yours handy for now, just in case.
Fyi, the Fosi Box X5 is an excellent value phono stage if you decide to replace yours. I ran it for a year or two until I recently upgraded to the Parks Audio Waxwing, which has quite a hefty price tag (for me) but also was worth every penny.
Thanks for your insight. I haven't had a phono stage for a long time, so I likely would not have realized where the electrical noise was coming from if it occurred.
There are also a few nice integrated amps out there that run Hypex, have top-quality phono stages, XLRs, good UI, display screens, all the streaming stuff, but you'll pay a premium if you need a compact all-in-one.
Thanks everyone I really appreciate the replies. The WiiM ended up not being for me (very slick but noticeably worse sound). Went back to the NAD pre + Schitt DAC with the Sonore streamer. Swapped in a Schitt Kara F and it sounds incredible. Was hoping to streamline but alas! I think I underestimated how incredible the Sonore is — may upgrade the DAC and phono pre, but honestly the separation is so good as is it would really only be for the love of the game. The Buckeye is Hypex with XLR outs. Cheers!
Separation? XLR outs on power amps?
Kara F looks nice. If you like tube / distorted sound then you might like the project tube box s2 phono stage. If your budget stretches though I'd still recommend the Parks Audio Waxwing if you have a digital optical input on your schiit DAC. If you don't fancy a digital phono stage then the Fosi box X5 provides a silent background. Probably on Amazon so you could try it and return it like with the Wiim if you don't like it.
Re: separation Being able to more clearly hear distinction of instruments across an array of frequencies and volumes (I could hear the details better and more distinction, say of a sax being played against a piano track — sorry if I’m not explaining this well! Is there another term for this?).
Re: XLRs, I am a doofus! Balanced XLR from Schitt to Buckeye, RCA out from Buckeye to speakers.
https://www.buckeyeamp.com/shop/amplifiers/hypex/ncx500/2_channel
I think I can hold off on upgrading at least for a little, gotta not spend too much time here
The ASR POV would be that WiiM Ultra is "transparant" and testing proves that, thus is should not sound inferior to other DACs. Tubes introduce second and third order harmonic distortion, which some find pleasing, and oftern describe as "warm" or "liquid." Objective vs. subjective. ASR is about objective. If you lean to the subjective on this forum, you will be called out a bit. No harm, no foul, just the philosophy here.
I think everyone knows what separation is, and that it's baked into recordings, and not a feature of the amp...
Makes sense, I suspect this was more about the WiiM as a lesser quality preamp, rather than solely as a DAC. Appreciate the context, definitely looking for more objective — think all the components in the current setup lean that way! Thanks for the reply .
