Current setup:
Roku streaming box with only HDMI output. The box streams music from it's own YouTube app; I also use the YT app on phone as a casting remote control so I can adjust volume, switch tracks, etc at a distance (all via wifi... there's no bluetooth awfulness involved!)
I have Roku box -> HDMI Audio Converter (Extractor) -> RCA line out to a nice vintage stereo amp and floorstanding speakers.
It works but the sound is bad (thinner, more distortion) than my previous, now obsolete, Roku box that had a built in analog output that went straight to amp... because I'm forced to use a crappy junk HDMI converter I bought, link here:
What to do? I looked at both SMSL PS100 which is a close replacement (minus the HDMI output which I don't need.) however it doesn't rate highly versus the SMSL SU-1 which I'd prefer to buy. The problem is the SU-1 has no HDMI input.... So I could either:
1. Keep the crappy HDMI converter purely for a HDMI -> Optical/Coax conversion and then connect that into the SU-1; now aside from questions about introducing potential jitter/digital degradation from this junk.... I believe I would totally lose the volume control would I not? I heard the Opt/Coax do not support it like HDMI direct to the DAC does? Or am I mistaken?
2. I buy a HDMI -> USB-C converter/cable and run that direct into the SU-1 from the Roku box.... but I thought the SU-1 also requires power via USB-C which HDMI can't provide can it? Or can I get a HDMI -> USB cable that can inject additional power?
If the above two options aren't possible what can I do?! I need digital/source volume control because I sit at the far end of the room often with a keyboard on my lap; and between song uploads the volume can vary on YT hence I need tap on my phone regularly to adjust it. I don't want to replace my amp and I'd rather not have to spend £60+ on some DAC that comes with its own remote control which is more clutter and less convenient to have to use two remote devices, one for track switching (phone app) and another dedicated remote control just for volume!
It looks like I'm stuck with the PS100 then, or is there some viable way to use the SU-1? Also I realise YT is not Tidal, or even full CD quality but some uploads on certain channels are in very good quality so perhaps a SU-1 would noticeably improve the sound over the PS100 right? Also if I stream lossless from the Roku which I do much less often, then it would surely matter.
Any advice is greatly appreciated, thanks
HDMI Audio Extractor Converter HDMI to HDMI & Optical SPDIF + RCA L/R Stereo | eBay UK
HDMI Audio Splitter Extractor: [Upgraded 4K@60HZ version] avedio Link HDMI to HDMI Audio Extractor Converter can extract audio from digital HDMI signals to amplifiers, Soundbar, speakers, etc. via optical SPDIF or RCA L/R stereo audio output.
www.ebay.co.uk
