Replacement for Tannoy 632
Sindzi
Hello,
I'm looking for replacement for Tannoy 632.
Is there anything on the market with the similar sound?
The budget is around $600 USD for the pair.
Thank you.
"Similar sound" is nearly impossible with speakers (or headphones). :(
If you can find reliable-independent measurements like the reviews here you can look at the frequency response. Otherwise you might have to take your chances with something that has a "similar design" or find an audio/video store where you can listen. And you MIGHT find something better!
ok.
In different words.
Which brand/model could you recommend within this budget?
- bookshelf speakers
- around $600/pair
- no strong basses, no metallic trebles, but warm perfect vocal
Thank you.
what about Bowers & Wilkins 607 S3?
Seems that it's a huge upgrade comparing with the previous S2 model...
seems all that are old models, in some reviews it was mentioned that S3 is significantly improved.
Here are some recent models:
Still the same treble boost:
Some suggestions within your budget:
Is the Elac DBR62 , mentioned by @staticV3 in #2, better than the Wharfedale Diamond 12.1? If you factor price into the equation, my answer is: I have no idea. Both are good speakers. :)
If you can think of used speakers, a pair of Revel M105 should be within your budget, I think:
FYI, the 12.1 is a Polk XT15 at double the price: https://www.audiosciencereview.com/...ield-with-high-sensitivity.63748/post-2336438
The way how you asked the question, it appears that your Tannoy has a colored sound?
If so, I implore you to spend the next 3 months on this forum and read as much as you can, you will then understand, you would want a neutral speaker, not a speaker with colored sound.
