Replacement ear-pads Senn HD600 ZMF Suede or Stock
Deckard01
Hello guys.
Has anyone tested the ZMF Suede pads? Do they worth for replace my HD600 or buy stock ones? Thanks
You'd be better off asking in the HD650 review thread than starting a new thread I reckon.
I've seen various measurements, some look quite similar to stock, others a decrease in treble I wouldn't be happy with. If you search there are some impressions, some people really like them.
Ok thanks I will ask there, I just look for HD600 not HD650 or HD6XX. The topic can close, thanks
I tried a bunch of different pads including sheepskin which look and feel the best without changing the sound signature much, but the ones I settled on are cooling gel. They increase the bass by a good amount due to the higher density of the foam. If you are a bass head like me give them a try.
I just ordered a few pairs of ear pads and the top part from china for 7 bucks each. Im expecting nothing and if theyre garbage, affect sound weirdly, i'll toss them and order original replacements, found for 35 pounds for ear pads and the foam headband combined. People say after market foam can really screw with the sound so will see.
stumble upon this thread from the internet, so did you came to any conclusion?
I'm more interested in how those Misodiko cooling gel pad or the leather pad change the sound.
A year late but the chinese replacements are actually great. Immediately bought 3 more pairs that should last me like 8 years easily. The fabric feels like original and i didnt notice any sound degradation. In fact it improved. Mine was completely worn out, basically drivers touching ears because of how worn out the pads were. Idk if im allowed to advertise but on allieexpress the seller is CP YANG STORE. 6.60 eur for the ear pads, the top headband and meshes. Originals would cost like 60 eur lol. 10x difference that my ears cant hear. Which is what i was gonna buy but couldnt find them in stock anywhere even on official senn replacement site at the time.
https://www.aliexpress.com/store/5361359?spm=a2g0o.detail.0.0.7c0bbzambzamQh
