Replacement Amp for my Revel Ultima Sub30
DocU
Long time lurker, first time poster.
I have a Revel Sub30 amp that the amplifier has gone out for the third time, granted this time it was my error pushing it a little too hard. Rather than paying George Meyer AV another $1000 to service the amplifier, I'd rather just purchase an external mono-amplifier to run the driver. Per Google, the specs for the Sub30 are as follows:
Driver & Acoustic Design
Active Driver: 18" composite cone with a 15" piston (15" forward-firing woofer) featuring a 3" 4-layer voice-coil, dual spiders, two copper voice-coils, and a 4.7 kg magnet.
Passive Radiator: 15" metal cone auxiliary bass radiator facing downward.
Excursion: 3" peak-to-peak excursion (275 cubic inches of true linear volume displacement).
Amplifier & Performance
Amplifier Type: Class-AB.
Power Output: 1 kW (1,000 watts) RMS, 1.4 kW (1,400 watts) peak.
Frequency Response: 20 Hz – 80 Hz (-3 dB at 18 Hz).
Peak Output Level: 126 dB peak output at 30 Hz.
I signal will be through XLR connection from my Trinnov Altitude16 so i won't need any crossover/timing correction with the amplifier. Attached are pictures of the blown resistors on the amp (I assume I've also fried some capacitors) and the Molex connector which is the driver's umbilical cord to the amplifier.
Could someone in this fine community give me a recommendation for an external amplifier to get my Sub30 up and running? My three requirements are that it must have a XLR input connection, be of smaller size (not much room to work with), and must run relatively cool (class D amp). Money is not a factor, but I would like to stay under ~$2k.
Many thanks in advance.
Since I received no response from this forum, I decided to post on another. Based on A member's recommendation there, I purchased a Buckeye Hypex Monoblock NC2k.
Good choice, I would have suggested a Crown XLS1502 in bridged mono mode, simply because in my experience they're indestructible, don't have experience with the Buckeye, although it's highly rated.
