ElectricSlide
- Joined
- Dec 16, 2025
- Messages
- 3
- Likes
- 1
Alright…short time lurker, first time poster. This may be better suited for the speaker forum, but thought I would post here and see.
Recently moved and setup our home theater/ tv/ music room. It is 60% HT and 40% music. Currently it is a hodgepodge as follows:
-5.1 with center a McIntosh lcr80, fronts are B&W matrix 805, and surrounds are Dali Oberon on wall. Subwoofer is a KEF k cube
-amp/ receiver is an Anthem MRX540 and goes to a Classe Sigma Amp5 (200 watts per a channel)
I changed my center speaker recently as I had less space/ depth than I would need for a traditional one. There was a screaming deal on a pair of new McIntosh lcr80s (got 2 for 1k). I’m only using one. After I pulled the trigger I realized how hard they are to power (81 db sensitivity), recommend 300W at 8ohms. Thus my questions is this- given this system would you:
A. Change out the classe sigma amp for a multichannel hypex NCx50s (or just add a mono block) that could power the McIntosh well (and even consider getting a third lcr80 and having a complete matching front set)
B. Pivot away from the McIntosh speakers (sell them and likely recoup what I spent) and get a Dali Rubikore on wall or something of that ilk that is easier to power for the center assuming you will eventually switch out the fronts for Dali bookshelves as well at some point
C. Something completely different
As an aside the McIntosh lcr80 does ok after I ran room correction with the current amperage. But I think it can be much better.
Would love to hear constructive thoughts…
