What don’t you like about it? Hard to recommend a replacement otherwise.I have rather quickly come to dislike the Apple Remote that comes with the dac 8. I’m wondering if someone can recommend a better rc
I don’t think that changing the remote is going to solve your problem.Ive had 2 audio buddies try to work out how to use it on the dac and they have no more luck than me
I want to play something, I chose the input and if it’s highlighted then that just undoes it
I go into the menu and only a few functions show I try to add more but it doesn’t happen. Highlighting doesn’t always happen
Whereas on my preamp remote it has 5 buttons for different functions and a volume dial
No idiotic menu like on the screen
The down button drops the volume but the up button doesn’t raise it back up but changes function
You end up in the wrong place and it’s easy, I suggest to change functions when you are trying to navigate. I can’t get optical to open, I highlight both of them then go out and they aren’t there in menu
The lack of basic symmetry in functions is terrible design
I have taught design and this would be a very low score
Previously offered Apple Remote is no longer in production. We are currently developing a custom-designed replacement. Until this is available, the dac8 Stereo can be paired with any remote that has a minimum of seven buttons.
Sounds like you've got a faulty unit. Changing the remote, which one can do, the DAC8 just have to learn the remote, will not change your problem.I want to play something, I chose the input and if it’s highlighted then that just undoes it
Are you with Okto. ?
