Relatively inexpensive MCH DAC / DDCs with DSP built in
john61ct
Branching discussion from such devices that are similar in function to the Topping DX1 II targeting consumers
This thread seeks to capture Multi Channel models, perhaps from the pro / prosumer realms, even if now only available secondhand
The **key** requirement is some sort of included DSP functionality, even if external 3rd-party software is requires to make use of that.
Any number of channels over a stereo pair, let's keep it to those that go for ~$100 or less per output port.
Analog I/O is ofc allowed, USB and S/PDIF the norm
but DDC output / format conversion more precious thus more leeway, especially ADAT and AES3
miniDSP Flex Digital is most likely the most straightforward option.
Pi Pico + DSPi if DIY is acceptable.
I **love** the potential of the DSPi project but let's keep it to finished products in enclosures or this will become all about the SBC / MCU boards!
At least, no soldering required?
miniDSP and RME are really in a higher cost per-port category, even secondhand. Not saying top notch quality isn't a fantastic attribute but let's please do a quick look at eBay and do a "price per output port" calculation, SOTA performance is def not a requirement here.
Of course if the count of qualifiers turns out to be only "a few" then maybe we'll go a bit higher.
Edit: also noticed that miniDSP has just one pair of S/PDIF stereo outputs, Coax + TOSlink? The company is so well-known even dominant as DSP, looking more for "diamonds in the rough" (cast before swine wrestling in the mud) LOL...
for those not code-averse
Okto Research dac8 PRO + AVDSP_DAC8 repository
as brought up here
and well discussed here
Look for "Warped FIR" if interested in real filtering and tap counts
