REL T5x connectiong to Vintage Marantz 2220B
johnsogr
Hello everyone,
I just picked up a vintage Marantz 2220B and had it restored, but the binding posts are the old spring loaded push pin terminals.
I'm curious how I can use REL's High Level Speakon cable with this amp. I think I have 2 options:\
  1. Activate both speaker output terminals "A" & "B", hook up my REL Speakon Cable to "B" and my Revel M16s to "A"
  2. Have Prosper Cables build me a Y-splitter that will have a flexible Pin going into the Marantz, that then Y's to two separate terminals to accept the REL Speakon in one and the Revel M16s in the other
Which is best? I like the idea of just using the "A" & "B" output terminals, but I'm concerned this will put too much stress on the amp, but to be honest, I don't understand resistance and loads and whatnot enough.
Thanks everyone for the help!
A & B are simply parallel binding post.
Normally you have to be careful connecting speakers to both A & B as the impedance drops (2 4 Ohm speakers = 2 Ohm impedance)
In case of a High Level input, this simply reduce speaker level to line level. It presents a high impedance to the amp to you can safely use it it in parallel with your speakers.
Do, probably the most convenient one.
