steve-z
Another A10 fan here, mines the uprated hand wired varian, I loved it the minute I started playing music through it.
I will admit the addition of the Aune x8 DAC has been a game changer, every aspect trounces my old +8k syste, I’m hands flat down on the table blown away by this little amp. Also it has no problems driving my ProAc Response 1SC’s.
Its a great piece of kit and ideally suited to a small study or sitting room.
Interesting to hear of someone using an A10 with a pair of speakers that some would think wouldn't be suitable, there's a guy on Youtube called Tarun who has a Youtube channel called "A British Audiophile", his primary system uses the same ProAcs, on quite a few occasions he's mentioned that they need an amp with plenty of power to get the best out of them, in his case that's probably true as his listening room is considerably larger than yours, I think that room size is the main factor in how successful the A10 works in your setup, if you want to drive a big room then speakers of 90+db/w will be needed with the A10. My Mission QX2s are 88db/w and are a good match for the A10 in my 4m x 3m bedroom, needing the 11 o'clock to12 o'clock position on the volume dial for my normal listening level. Since my last post I've also swapped from the 4ohm to the 8ohm taps on the A10, the 4ohm taps which I've been using with my Frugelhorn Lites initially and then the QX2s sounded fine but swapping to the 8ohm has been beneficial, tightening up the bass a little and giving the treble a slight lift.
