Well I went for it and ordered an ND7. Listening tests tell me it sounds much better than the exact. Ran some measurements and got the below.
SJPlot using Nyquist correction script for Ortofon LP:
47k/100pf(ish) loading.
-Channel Balance is basically spot on.
-Distortion is lower than the Exact. This is clarified further below.
-Crosstalk performance is much better.
-Frequency response it's an improvement but still not flat. Peak is less significant and reaches 20k before rolling off >= 1db(ish). I personally still feel that Rega could do better in this regard.
REW 1khz distortion:
-Definitely fewer distortion spikes present than the Exact.
-Ignore 50khz spike - the 1khz tone on the Ortofon LP is near the middle, so picks up some hum from the synchronous AC motor. I will probably experiment with grounding the motor casing at some point to try and improve this.
For giggles I also performed a frequency sweep using the same method I used in my original post:
It might not be accurate, but still interesting to see the flatter frequency response and even channel balance.
Personally I would still like to see a flatter frequency response provided by Rega cartridges. But at least they have improved things both subjectively and objectively
