Dgob
Is there a phono preamp that you would recommend for use with a pair of KRK ROKI 5 Gen 4 monitors?
Is that your system, or the one you are benchmarking?Many thanks 617, I have a variety of MM/MC cartridges and so will probably go for the Emotiva or Cambridge Duo. I'm a little worried as I want to use this second, budget system as my main one now that space and a spouse make playing my main system impossible. Do you think the two items will place me in a position to hear near audiophile sound from a system that will include my Technics SP10 MK2 turntable?
https://systems.audiogon.com/systems/446
Many thanks again, your help has been invaluable.
Hi Again 617 and ALL,
I just came across my Highphonic MC-D15 cartridge and thought it would be nice to be able to get it up and running again.
Would the Emotiva or Cambridge Audio be able to drive it with its 0.129 mv output? If not, is there another phono preamp (or step-up transformer) that you would recommend to get the best out of this cartridge?
Many thanks in anticipation
Many thanks 617,
I definitely can't claim to be an expert on any aspect of hifi and so your help is more appreciated than you might think.
I noticed on the Workbook that you kindly supplied that Amir tested and recommends the Musical Fidelity MX-Vinyl phono preamp and that this has the option of a 0 dB and a +6 dB gain setting. Although currently beyond my price point, do you think that (once saved for) this might enable me to get the best out of my Highphonic? I ask because I would dearly love to be able to play it within the confines of the budget(ish) system that I am trying to establish.
Again, my gratitude precedes your anticipated response
Sorry,
But the way I posed this question might be part of the reason why it received no response. However, I cannot believe that in the intervening decades since I bought my CD7, that DACS and cdp performance have not moved on considerably. What I would love to find is a cdp that provides greater neutrality, transparency, detail, and accuracy than my now aging Marantz. It was in this light that I asked if:
"anyone would know of a better (more neutral and accurate) CD player that would exceed the performance of my CD7 and therefore remove the need of my having it repaired?"
Any help and advice will be greatly appreciated.
Thanks again,You can use your current CD player as a transport, and use its optical or coaxial outputs to feed a standalone DAC. Fortunately this is one area where technology has progressed immensely, and you can have audibly perfect audio from your CD collection for a minimal outlay.
You can get, for example, a Topping E30:
https://www.audiosciencereview.com/forum/index.php?threads/topping-e30-dac-review.12119/
Which produces noise and distortion that is 112db quieter than the main signal. It surpasses the physical limitations of the CD format by 16db.
I can't say it will sound better, but I can say that the performance from a technical perspective is effectively perfect.
Personally I don't have a CD player now, but if I did I would get a vintage machine which I enjoyed operating, and feed it into a modern DAC like the Topping.
One other thing,Thanks again,
That was exactly the type of information and suggestion that I was seeking. I will now look into getting the Topping E30. Would that apply to its being used on both/either of my Marnatz's: the CD63 KI and/or CD7?
If so, I can delay the outlay that I have been quoted to have the latter repaired and invest that in the suggested DAC.
Digital output from CDP to digital input on DAC. Usually TOSLINK fiber optic cable or S/PDIF coaxial cable.One other thing,
How would I connect and set it up with my CDP?
Many thanks HelicopterDigital output from CDP to digital input on DAC. Usually TOSLINK fiber optic cable or S/PDIF coaxial cable.
Thanks again,
